Activity Forums Apple Final Cut Pro Legacy Toast 10 vs Encore
  • Kevin Monahan
    January 24, 2010 at 6:44 pm
    I’m surprised no one mentioned that you can make Blu-ray discs right out of Final Cut Pro. Have you explored the “Share” protocol? I’ve burned 100 discs already with no issue.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Greg Barringer
    January 24, 2010 at 7:15 pm
    I’ve used FCP to burn AVCHD to DVDSP using the regular superdrive. Are you using a BD burner?
  • Michael Sacci
    January 25, 2010 at 3:48 am
    Look up the new features of FCP7 and Compressor. For these BluRay disc you DO NOT go into DVDSP.
  • Greg Barringer
    January 25, 2010 at 3:55 am
    Thanks, I ordered Toast 10 Pro.
  • Craig Sawchuk
    January 25, 2010 at 1:48 pm
    Just curious — will compressor allow you to burn Blu Ray content onto DVD media using a DVD burner that will reliably play in Blu Ray players? Never tried this but it could be a good bridge….
  • Rich Rubasch
    January 26, 2010 at 2:15 am
    Not sure, but Toast does it pretty effortlessly.
    Rich Rubasch
    Tilt Media Inc.
    Video Production and Post
    Owner/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Alan Lacey
    January 26, 2010 at 4:54 pm
    Toast won’t burn you a BD that you can replicate from. I found that out the hard way.
    Alan
    FlashXDR,XDcamHD,XDcamEX,D9 etc
    FCS,AE,Combustion,LiquidSilver,Vegas,Edius,
    G5,MBP,Vista64,XP
  • Larry Applegate
    January 27, 2010 at 2:43 am
    Hi Alan,
    We offer BluStreak Premaster for replication from both Toast and Encore (or any BD authoring application). It was released last May.
    Regards,
    Larry Applegate
    https://blustreak.dvdafteredit.com/
  • Greg Barringer
    January 29, 2010 at 5:28 pm
    I now have FCP7, Toast10 Pro, Panasonic burner BDR-205 on a Mac Pro eight core and a BD-RE to test with. 50 BD-R are on the way.
    I’m trying to use Toast to author a BD with a menu. The results are horrible, I believe this is caused by Toast encoding. If I use Share directly from FCP it looks outstanding on a Sony BD350 and LCD TV but there is no menu. I also tired Share to create a BDMV folder which works in Toast and looks great but doesn’t have a Toast menu.
    I’ve tried different settings in Compressor but Toast Encodes it each time. Any ideas?
  • Greg Barringer
    January 29, 2010 at 7:50 pm
    I’m slowly getting there. Toast is still encoding but it looks better.
Page 2 of 3
