Activity › Forums › Adobe Premiere Pro › Timecode off between Quicktime file and PP
Bruce Little replied 13 years, 6 months ago 3 Members · 14 Replies
John-michael Seng-wheeler
April 30, 2012 at 8:42 pmSo I just hit a similar bug, and I think I might have found the problem.
The files you were having trouble with weren’t created in MPEG Streemcilp were they? I’m having similar timecode reading issues with ProRes from MPEG Streemcilp in Premiere, and I discovered that Premiere thinks that the files are Non-Drop Frame, when the original files (HDV captured in FCP) were Drop-Frame and MPEG Streemcilp wasn’t told to change the frame rate.
I don’t know if the problem is MPEG Streemcilp, Quicktime, or Premiere, but it’s sure annoying.
Bruce Little
March 5, 2013 at 7:26 pmHas this timecode issue been fixed?
I am having same problems. PP timecode does not match what is in the quicktime. NDF or DF does not matter. If the quicktime is DF PP sees it as DF, same with NDF. I have files that have been captured and then exported with AVID. Every other app sees the timecode correctly except PP. Why? So very frustrating.
I have found that if I render files from Resolve then, and only then do the timecodes match.
Has anyone found a solution?
Bruce
