Activity › Forums › Sony Cameras › Time-code Format
  • Stephen May
    February 3, 2009 at 4:26 am
    Eric – to your original goal – syncing video to sound:
    In a multiclip you can assign an aux timecode to a clip, so that if you use a clapper or some cue – say you’re recording a band and they’re doing multiple takes to a song, you can just make your (visual) marker, like a flash or a sharp clap, sync each clip via the AUX 1 timcode to the final mix, and then via the aux TC be in sync for the rest of that clip.
    Stephen May
    Keystone Media Productions
    Freelance Videographer
  • Rafael Amador
    February 3, 2009 at 8:30 am
    Sure.
    You can sync your EX-3 to any incoming TC signal (BNC) or you can sync other machines to your EX-3 TC output.
    The question is how you set the TC in the Audio recorder. If this would have BNC TC IN, you would need just one cable.
    Rafael
    http://www.nagavideo.com
Page 2 of 2
