Activity › Forums › Apple Final Cut Pro Legacy › The theory and mechanics of rendering in Final Cut Pro
James Mortner replied 15 years, 6 months ago 5 Members · 14 Replies
Rafael Amador
March 9, 2011 at 1:51 amHi Miranda,
“.dv” (DV Sequence), IS NOT SUPPORTED by FC. Always needs to be rendered, and as Andy suggests, the file will be flattened to before processed by FC.
That shouldn’t be on your sequence.
I would start by trying to re-wrap that stuff again as QT.
You may try MPGStreamclip: “Save as > QT”.
No rendering required and you may get back the graphics with the proper attributes on a proper QT file.
rafael -
Miranda Raimondi
March 9, 2011 at 1:57 amThank you Rafael. Thank you to all who contributed to this thread.
Miranda Raimondi
Samples of my collaborative work with Dr. Samuel Pellman are available for viewing at http://www.vimeo.com.
Please search ‘Samuel Pellman’ or ‘Miranda Raimondi’ in vimeo.com’s search function in order to view those samples.
James Mortner
March 9, 2011 at 2:07 pmVery interesting thread everyone !
Just to add, don’t the black dots on the edge of the doecahedron graphic in the PDF look like alpha masks gone a bit wrong ?
If you select the clip in the timeline and press “cmd_9” again, try changing the alpha properties by right-clicking on the word “straight” next to “alpha” and selecting black, white or ignore. This might change the way the dv clip composites and renders.
But i would still find a better format like the others said.
Cheers !
