Activity › Forums › Panasonic Cameras › The Mexican American War – Airdate
Shane Ross replied 19 years, 11 months ago 10 Members · 19 Replies
Shane Ross
September 27, 2006 at 2:49 amIt matched very well. And yes, the trailer is a mixture of Varicam and HVX-200. Can you guess which footage is which?
Shane
Littlefrog Post
http://www.lfhd.net -
Mitch Ives
September 27, 2006 at 4:17 am[Shane Ross] “Since FCP doesn’t do insert edits well at all, we fixed them in a linear bay by adding a slight verticle blur.”
I’d be interested in hearing your logic on that point…
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.comApple Certified Trainer: Final Cut Pro 5
Shane Ross
September 27, 2006 at 4:24 amFCP isn’t 100% accurate when you do an insert or assemble edit to tape. This from practical experience. A couple times when I output a show, first picture didn’t start at 1:00:00:00 like it should, but rather 1:00:00:01, or :02…and once at :00:59:59:23. Luckily for this show…a 90 minute show…it hit the hour mark right on. But, the 1:00 promo didn’t. It hit the 1:00:00:02 mark the first time.
Then I had to fix the credits…add a name. We went to insert ONLY the credit bed at then end of the show. Black before and after picture, so I felt safe. It took 4 attempts to get it to hit the right frame..always one frame off. Either short or long. Now, because of that, I didn’t want to go doing this 20+ times in the middle of a show and risk adding black frames or double frames.
This is a serious issue that Apple needs to address.
Shane
Littlefrog Post
Mitch Ives
September 27, 2006 at 2:22 pm[Shane Ross] “FCP isn’t 100% accurate when you do an insert or assemble edit to tape. This from practical experience. A couple times when I output a show, first picture didn’t start at 1:00:00:00 like it should, but rather 1:00:00:01, or :02…and once at :00:59:59:23. Luckily for this show…a 90 minute show…it hit the hour mark right on. But, the 1:00 promo didn’t. It hit the 1:00:00:02 mark the first time.”
I know some people think that, but it’s incorrect. It’s pilot error. I can get 100% accuracy every single time doing insert edits, and always have for 4 years now. Same timecode in point 100 out of 100 times. I’ve even done it on a lowly DSR-11. On more sophisticated decks, it’s a given.
Apple doesn’t need to fix anything. You might want to do some research and then calibrate your decks and FCP…
Mitch Ives
Shane Ross
September 27, 2006 at 3:08 pmPilot error eh? Since this issue is one that is known at three post houses that use FCP (one that is designed around FCP from the ground up) I don’t believe this is pilot error. You might be an anomoly, which isn’t surprising. There are things that I can do that 80% of FCP users cannot do. The fact that you get 100% accurate insert edits is great. Just know that it isn’t the norm. It is an issue that every facility that uses FCP knows about.
Shane
Littlefrog Post
Arnie Schlissel
September 28, 2006 at 7:58 pm[Shane Ross] “Friday, Sept 29 at 8:00PM ET/PT on The History Channel.”
Nuts! I’m still in Moscow, & my apartment here doesn’t have cable. I’ll just have to catch a re-run.
Congrats!
Arnie
On location in Moscow for Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Mitch Ives
September 29, 2006 at 3:59 am[Shane Ross] “Pilot error eh? Since this issue is one that is known at three post houses that use FCP (one that is designed around FCP from the ground up) I don’t believe this is pilot error. You might be an anomoly, which isn’t surprising. There are things that I can do that 80% of FCP users cannot do. The fact that you get 100% accurate insert edits is great. Just know that it isn’t the norm. It is an issue that every facility that uses FCP knows about.”
Well, I suppose if they calibrated their decks and made the adjustments in FCP that I do that they would all be able to do it. Nothing supernatural about what I’m doing…
Mitch Ives
John Frey
September 30, 2006 at 2:16 amJust viewed “The Mexican American War” on the History Channel. Good job, Shane. A well-told story with nice production values. I’m guessing that the HVX-200 was used in the close-quarter handhelds in the midst of infantry? When will we see your next project?
John D. Frey
25 Year owner/operator of two California-based production studios.Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
Shane Ross
September 30, 2006 at 3:10 amThank you.
The HVX was used for a majority of the battle scenes. We use the Varicam for the interviews, b-roll and the main character footage. But while the main character footage was being shot, the 2 HXV cameras were off shooting battles. Either the same battle from different angles, or one shooting a battle while the other shot the guys lugging a 1-ton cannon up a hill (those poor San Patricio actors…I feel for them). I’d say 70% of the recreations were HVX.
Shane
Littlefrog Post
http://www.lfhd.net
