Activity › Forums › Apple Final Cut Pro Legacy › That DVCPROHD Re-Import Scurge
Matthias Halibrand replied 18 years, 9 months ago 5 Members · 14 Replies
Bill Bilowit
October 25, 2007 at 11:11 pmFinally some progress with my three DVCPRO HD 1080 23.98 timelines needing to export out and come back into a fresh timeline as single clips, for a feature length final cut.
I used a suggested fix from an earlier thread that had not worked for me, but made an adjustment. I end up recompressing, but I seem to have no choice not to.
1) Exported my timeline with current settings as a ref movie, only took a minute or so.
2) Opened that ref FCP QT in Quicktime; under Properties-Video Track I changed the scaled size width aspect to 1280, unchecked Preserve Aspect Ratio, saved, renamed the file. Made sure it opened again in QT as a 1280 wide clip.
3) Imported this ref movie into FCP, from the browser exported it as FCP QT but instead of current settings I selected the format I’m working in (DVCPRO HD 1080 24). [I did not export with Quicktime Conversion]
4) Imported the resulting FCP QT (about a 50min. render for a 30min timeline) and it plays fine in a fresh sequence.
Another suggested workaround was to simply export the original timeline and choose Recompress; it didn’t work for me, plus that render was 25% longer duration than the total adventure described above.
If anyone ever finds a consistent cause of this issue, or even better a better fix, make a post please!
Matthias Halibrand
December 12, 2007 at 12:03 pmHi,
that problem seems to be partly fixed with FCP 6.0.2, there is still a glitch in it however.
When opening the exported clips with QuickTime Player and hit CMD-J, it should show Normal Size as 960×720 and Display Size as 1280×720, as it does with anamorphic PAL (720×576 and 1024×576) but it does display both as 1280×720.
But at least the FCP-Workflow is correct, again.
Bill Bilowit
December 12, 2007 at 2:53 pmThanks for following up…
So do the resulting natively exported clips play on your timeline, or must they be rendered?
Matthias Halibrand
December 12, 2007 at 4:09 pmThey play native without rendering needed.
Regards,
Matzehali
