Activity › Forums › Maxon Cinema 4D › Texture – Sculpting issues
  • Kelum Jayasinghe
    August 9, 2014 at 8:10 pm
    Yes Emir, Current State To Object works…Thanks!
    Cinema 4D ROCKZ!
  • Adam Trachtenberg
    August 9, 2014 at 10:45 pm
    In some cases you may want to bake down to the second or third subdivision level, too, instead of baking all the way down to the lowest level. That way, if you’re using existing UVs, the resulting UV maps will be closer to the displaced result.
  • Kelum Jayasinghe
    August 9, 2014 at 11:03 pm
    OK Adam..will keep the tip in mind..Thanks!
    Cinema 4D ROCKZ!
Page 2 of 2
