Activity Forums Apple Final Cut Pro Legacy Text quality changed
  • Omar Estrada
    October 6, 2008 at 7:53 pm
    Sorry Alex,
    “changing your compressor from HDV to ProRes”
    … means, rendering/exporting from my HDV 720p, 23,98 sequence using ProRes HQ? taking everything to a ProRes HQ sequence and render/export from there? or setting something in Compressor?
    Thanks again, guys!
  • Omar Estrada
    October 7, 2008 at 1:32 am
    Thanks guys for the help.
    I think that there were probably problems with my system since after troubleshooting my FCP texts look ok.
    Related to my PS text, I´m still reading…
    If I get to fix it, I will post the solution here.
  • Alex Elkins
    October 7, 2008 at 7:43 am
    Hi Omar – sorry, what I said about compressor settings may have been misleading. I’m not talking about Compressor (the software) I’m talking about your actual sequence compressor/render settings. Go to Sequence>Settings (or press CMD+0) and under ‘Compressor’ change it from HDV to ProRes (personally I don’t use ProRes HQ as I don’t see enough difference in quality to justify the higher file sizes, but it’s up to you.)
    [Omar Estrada] “… means, rendering/exporting from my HDV 720p, 23,98 sequence using ProRes HQ”
    CORRECT.
  • Omar Estrada
    October 7, 2008 at 5:12 pm
    Thanks Alex!
    I´m following the advices to test the quality after exporting… I´ve been trying weird walkarounds as I love the “alternative logic” of the great editors out there, like trying vector objects and stuff, but I still don´t get a significant improvement.
    So, that´s maybe the quality that it is.
    Thanks again, everybody!
  • Omar Estrada
    October 9, 2008 at 4:22 am
    Well guys!
    Once I was able to process all the information I found about how to improve graphics in our FCP projects, I solved the problem.
    Thanks a lot
Page 2 of 2
