Activity › Forums › Adobe After Effects › Text Layer Display Current Sound
  • Ryan Oneil
    July 13, 2011 at 6:18 am
    Are all the sound effects the same size?
    If so, why not just use keyframe assistant? Put all the layers in and create them all with the same length (say 2 seconds each). Use the keyframe assistant to sequence the layers. (Animation->keyframe assistant->sequence layers…) Choose no overlap. This will sequence all of your sound layers one after the other.
    Let’s say X=number of layers you have.
    Then, do the exact same steps with X copies of the text layer we’ve been discussing (with source text property expression being thisComp.layer(index+1).name) The only difference, instead of putting +1, put -X. After you use your keyframe assistant, all of your layers will magically be in place!
Page 2 of 2
