Activity › Forums › Apple Final Cut Pro Legacy › Terrible Sync Drift – BWF Metadata set to 25FP S- Need FIX
Jeremy Garchow replied 17 years, 11 months ago 3 Members · 15 Replies
Jeremy Garchow
October 27, 2008 at 4:41 pm[Jonathan Rotberg] “Or will that not change the “tagging” on the audio files that are part of the merged clip?”
Correct. You will have to try agian.
Try the fix with ONE clip first and see if it even helps you. After that, then we decide what’s next.
Jeremy
Jonathan Rotberg
October 27, 2008 at 6:30 pmOk GREAT.
So when I set the settings to Offline RT HD -24 with frame rate at 24.00. The clips merge correctly with no drift.
AND!!
I figured out a way to reconform my already merged clips. All I have to do is open a new project file with the easy setup settings set correctly. Then I bring my bwf files into that. Then open my old project and all the audio in that has been retagged so its all in sync. The I save my old project and its all good.
Let me know if you think I’m wrong about that, because it looks good on my side.Isn’t that awesome?
Jonathan Rotberg
October 27, 2008 at 6:42 pmYou’re great. Thank you so much.
You can send your invoice to my people.
ha!
Jeremy Garchow
October 27, 2008 at 7:53 pm[Jonathan Rotberg] “You can send your invoice to my people. “
The bill is in the mail.
