Activity › Forums › Adobe After Effects › Technique for Animated Number Countdown with Commas
Claire Presnall replied 3 years, 1 month ago 26 Members · 27 Replies
Nick Hamilton
November 26, 2015 at 12:07 pmAnd if you would like to count over 1,000,000 and keep the comma’s in:
startCount = 0;
endCount = 48000000;
countDur = 3;var num = Math.round(linear(time,0,countDur,startCount,endCount))
num = Comma(num);
[num]function Comma(number)
number = ” + Math.round(number);
if (number.length > 3)
var mod = number.length % 3;
var output = (mod > 0 ? (number.substring(0,mod)) : ”);
for (i=0 ; i < Math.floor(number.length / 3); i++)
if ((mod == 0) && (i == 0))
output += number.substring(mod+ 3 * i, mod + 3 * i + 3);
else
output+= ‘,’ + number.substring(mod + 3 * i, mod + 3 * i + 3);
return (output);
else return number;
Liran Tabib
April 22, 2016 at 7:12 amyou can use a different approach and create the animation with the counter preset: https://www.vdodna.com/products/counter-preset/
David Crowther
April 24, 2017 at 8:00 amNew response to old post, this helped me a lot with a project I am working on. However, I used point control instead of slider to overcome the arbitrary 1,000,000 limit.
The expression was (including commas):
var num = effect(“Point Control”)(“Point”)[0]
num = Comma(num);
else
return (output);
else return number;
Jameel Choudhury
June 20, 2017 at 2:12 pmHi David,
This expression is extremely helpful for what I need in my project. I just had 1 question, how do I go about including a £ or $ symbol at the beginning of the number as it counts up?
David Crowther
June 20, 2017 at 6:22 pmHi Jameel,
You can add it to the num variable like so:
num = “$” + Comma(num);
else
return (output);
else return number;
Erik Waluska
October 30, 2018 at 4:54 pm -
Tomáš Lyga
November 6, 2018 at 12:19 pmHi, for some reason this code (or any other similar to this one) doesn’t work with Adobe After Effects CC 2019. Do you have any idea why is that? Thank you
Magdalena Kašparová
March 8, 2019 at 11:46 amIn CC2019 first go to: File • Project Settings • Expressions ; set it to Legacy ExtendScript
Milan Karmakar
June 21, 2019 at 7:29 amHi There,
the Expression not working in my after effects cc 2019 version.please help me out
