Henry Blood
July 17, 2006 at 7:52 pmReally,
I just thought that perhaps since FCP has the abillity to look at processor speed and adjust real time playback that SW on a G5 could do so as well. Of course they are different softwares but I think it’s the same principle and maybe the velocity engine would be the common key.
Thanks A.D.HB
Floh Peters
July 18, 2006 at 8:34 am[Arthur Dent] “I don’t think v11 or SW has a capablity to check the processor speed and compare that against what’s on the time line in determing what it can play in real time.
The yellow bars simply indicate what, in an ideal world, the appliation *should* be able to play back in real time.
“The yellow bars indicate Realtime Effects on a clip; the system does not “calculate” the amounts of realtime effects and layers you used vs the CPU speed; so while it is yellow and marked as a realime effect it is not sure it will actually play in realtime.
