Activity › Forums › Apple Final Cut Pro › SUPER USEFUL: Use clean title as adjustment layer
Andy Nickless replied 14 years ago 10 Members · 15 Replies
Pavel Pavlov
July 14, 2011 at 3:01 pmIts great! Like Avid style where i can use effects to empty track over clips
Andy Nickless
September 3, 2012 at 5:54 amBrilliant – but limited!
What a great idea this is – it works a treat! The only problem for me is that it affects everything beneath the adjustment layer – that means any clips below the one I want to add an effect to, are affected too.
Despite this, I’m sure I’ll be using this a lot – (thanks)!
AndyI’ve taught you all I know, and still you know nothing.
Mark Spencer
September 3, 2012 at 1:33 pmWell if you want to limit your effects to specific clips, then just put them in a compound clip and apply them directly to the clip – no need for an adjustment layer
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Andy Nickless
September 3, 2012 at 1:49 pmThanks Mark – yes, I’m aware of the advantages of Compound Clips but I wish Apple would give us Paste Effects as in legacy FCP.
Andy Nickless
September 3, 2012 at 2:36 pmInterestingly, if you make a Compound Clip of your connected clip with the ‘adjustment layer’ attached, the adjustment only applies to the clip within the Compound Clip. Any clips below, revert back to their previous state.
Not sure whether this is of any practical use, but it’ 15.30 here and I’ve been up since 03.30 this morning, so the thought process is even slower than usual!
