Activity › Forums › Adobe Encore DVD › subtitle or menu subpicture too complex – HELP
Sylvain Sailler replied 11 years, 5 months ago 11 Members · 23 Replies
Jimmie Schmoranz
December 17, 2012 at 6:04 amRemoving the outline is the only thing working for me.
However, the text is now impossible to read against bright backgrounds so the problem isn’t really fixed.
I also read about someone changing outline to bold and got it to work but that’s not working for me. Nor is changing the left and right parameters.
Honestly, if this problem has been known since CS2, why hasn’t it been fixed? I thought this software was made for professionals.. :/
Anyone heard of a bugfix, or some other way? It can’t just be random. Then different solutions would work different times.
Sebastian Leitner
January 2, 2014 at 4:13 pmi just want to concur quickly! if i disable outline (set it to “none”) i can have any values of the other options they do not get in the way at all. i’m on mac and cs6
Sylvain Sailler
March 31, 2015 at 11:47 amI had the same issue and didn’t find anywhere anything to solve it. Finally the solution to keep the outline on was to set up the font to bold. I suppose it makes characters more clear and therefore less complex to code.
