Activity › Forums › Apple Final Cut Pro Legacy › stuttering or strobing clips on playback
Rachel Lippert replied 15 years, 5 months ago 5 Members · 16 Replies
Rachel Lippert
March 9, 2011 at 6:10 pmWayne. I think that is my problem. I import the files directly from my camera to a hard drive, then import into FCP. So this means that I have to convert every file to prores422? Like through compression? I feel like such an idiot b/c i went to school for film but am by all means not an editor. I know there are better people out there for the job.
Mark Maness
March 9, 2011 at 6:29 pmNo, you have to import your media thru Log and Transfer. But before you do this, backup the entire contents of your SD cards first. Archive them to DVD or BluRay for later use, if needed.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Mark Maness
March 9, 2011 at 6:57 pmYou can use Compressor but you can import into Final Cut Pro using Log and Transfer and using this to convert to ProRes422.
But before you go too much further, I would suggest that you look at some tutorials on FCP here on the COW. You really need to be more familiar with the software.
Wayne Carey
Schazam Productions
Mark Maness
March 9, 2011 at 6:58 pmYou can use Compressor but you can import into Final Cut Pro using Log and Transfer and using this to convert to ProRes422.
Wayne Carey
Schazam Productions
Rachel Lippert
March 9, 2011 at 8:04 pmWOW! Thanks so much! Definitely should’ve looked harder… I understand now. Thanks so much!
