Activity › Forums › Adobe Premiere Pro › Strange Problem…Can’t right click on some clips!?
Reid Price replied 8 years, 9 months ago 14 Members · 19 Replies
Alexandros Iliakis
May 11, 2016 at 9:59 amUsing a mac we use to hide the dock when we open an Adobe application to have more space. This cause the problem to Premiere Pro because it cannot find out whether the dock is hide or not. This is strange I know but this is the main problem.
Solving your problem is not change workspaces and stuff. Just hide and unhide the dock – resize the window and everything works back normal -
Jeff Bugbee
September 16, 2016 at 7:08 pmI’ve updated to Premiere 2015.3 and this issue still exists. The solution is still to change workspaces.
Alexandros Iliakis
September 17, 2016 at 5:54 amThe problem comes when you hide or unhide the dock on mac. When open a project and you hide the dock in order to get more space, the next time you open the project again but forgot to hide the dock again – then this problem comes. So you just hide or unhide the dock again, reposition Premiere s window and you are fine. no need for changing the workspace I guess.
At least that works for me.Im using 2 displays, i need to reposition both of them.
Jeff Bugbee
September 17, 2016 at 6:38 amI’m not following you. My users already have the dock hidden. They haven’t made any changes in days. Yet only today they were unable to right click.
Alexandros Iliakis
September 17, 2016 at 10:53 amJeff sorry for my english.
In my case the problem is the size of premiere window when you hide the dock. If you never hide the dock before, you may never had this problem.Try to resize pressing the green button, then resize manually to where you want by dragging. Also hit alt+cmd+D to hide the dock several times to make Premiere understand what is happening.
Vedran Senjanovic
November 29, 2016 at 10:46 pmAnyone got this on PC?
It seems Adobe thinks this is only a MAC issue on their forums. Also freezes when dragging the clip (the one I can not right-click). Only solution (PC, W10) is to start a New Sequence and then it’s OK again.
Cheers ~
Kris Strobeck
February 6, 2017 at 8:52 pmWhat worked for me, FINALLY, is to go to the top computer menus while in Premiere and select Window/Workspaces/Reset To Saved Layout… then I set it back up how I wanted really it. All I had done was drag the screen to another monitor…
Reid Price
December 3, 2017 at 12:04 amWas having this issue on CC2017 Mac, I’m using dual monitor w/ hdmi, and what fixed the issue for me was just unplugging and re-plugging in the monitor. Very, very strange and annoying.
