Activity Forums DaVinci Resolve Standard Candle 9.0
  • Sascha Haber
    September 25, 2012 at 11:54 am
    The conclusion is correct, the test itself does not go to much in depth.
    Who used only three nodes ?
    I designed this one to work with single CPU card solutions up to the biggest multi GPU system.
    And you can run it yourself 🙂
    A slice of color…
    Resolve 9.01 OSX 10.8.2
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Neil Roberts
    September 25, 2012 at 7:14 pm
    Thanks for this thread guys.
    I am running a Mac Pro 3.1 with a GTX 660ti
    These are my results in DaVinci Resolve 9 Lite:
    V00 02 blur nodes 24 fps
    V01 04 blur nodes 24 fps
    V02 08 blur nodes 19 fps
    V03 16 blur nodes 11 fps
    V04 32 blur nodes 06 fps
    V05 64 blur nodes 03 fps
    More info on my blog here:
    https://nrsotw.blogspot.co.uk/2012/09/gtx-660ti-in-mac-pro-and-davinci.html
  • Andrew Smith
    September 27, 2012 at 12:46 pm
    Does anyone have the test – the yousendit link has expired?
  • Kim G. rasmussen
    September 27, 2012 at 2:00 pm
    Mac Pro 12 core 2.4GHz / 24GB ram / HDPro2 16TB
    Quadra4000 GUI / 3xGTX 680 4GB in Cubix box
    OS 10.8.2 / DaVinci 9.0.1:
    V01 04 blur nodes 30 fps
    V02 08 blur nodes 30 fps
    V03 16 blur nodes 30 fps
    V04 32 blur nodes 30 fps
    V05 64 blur nodes 20 fps
    V06 01 NR 2 nodes 30 fps
    V07 03 NR 2 nodes 30 fps
    V08 06 NR 2 nodes 30 fps
    kim@stjernholmco.dk
  • Neil Roberts
    September 27, 2012 at 2:29 pm
    Wow Kim!!!
    I feel inadequate now 🙂
    Do the GTX 680’s run with the standard Cubix power supply?
  • Kim G. rasmussen
    September 27, 2012 at 2:34 pm
    Standard PSU, but I had to remove the fans on one of the cards in order to fit 3 of them :-/
    (Running “burn-test” now…)
  • Sascha Haber
    September 28, 2012 at 9:14 am
    Interesting you are getting 30 fps in a 24fps project.
    But the perfromance…wow…thats killer
    A slice of color…
  • Kim G. rasmussen
    September 28, 2012 at 9:25 am
    HaHa, that’s kind of funny, someone must changed the project setting, unless that’s a new feature of v.9?!
    Anyway, the media file is actually 25fps, so I guess I’ll need to rerun the test 🙂
    R&D&QA, IT/AV support
    kim@stjernholmco.dk
  • Kim G. rasmussen
    September 28, 2012 at 9:38 am
    Doesn’t change the result, still 20fps with 64blurz…
    kim@stjernholmco.dk
  • Kim G. rasmussen
    September 28, 2012 at 10:28 am
    Forget everything I wrote before!”#€
    The guy who loaded the project had changed the project to NTSC, so all the numbers are total BS 🙁
    Guess it’s still true that you have to do everything yourself, or waste your time checking :-/
    kim@stjernholmco.dk
Page 2 of 5
