Activity › Forums › Adobe After Effects › Stabilizing to remove an element then reintroducing the camera movement
David Dubois replied 19 years, 7 months ago 5 Members · 13 Replies
Sam Moulton
February 21, 2007 at 5:05 pmSounds much to complicated for me. When I stabilize footage so I can work on something or add something I always expand the dimensions of the comp where the stabilized footage lives then do my work. I then then drag the comp into a standard size comp and add a simple value+ expression to the nested comp’s position property. This restores all movement to the original footage and fits it back in the frame.
something like this:
value + comp(“NestedBigComp”).layer(“stabilized footage”).anchorPoint
Sam Moulton
February 21, 2007 at 5:18 pmforgot to say that if you are working with footage that’s the same size as your comp and you don’t want it to move you don’t need the value + statement. I’ve been working with HD projects that are full of stabilized and positioned sd footage in windows. sorry for the confusion
David Dubois
February 23, 2007 at 10:20 amThanks for all of the ideas.
I suspected expression might have to rear their ugly heads (I am trying to use them more)! and the Null objects also cleanedd up the process a bit.
As I’ve done a dirty fix on the problem It’s working for now BUT when I’ve finished cutting the film I’ll try these out and feedback with any questions/comments.Thanks to all again for helping to clean up my dirty, dirty process!
Dave
G5 2.5 Dual
2.5 gig ram
x800 xt
1TB media storage
23″ Cinema display
19″ IBM LCD – used for Cinema Display
FCP Studio (FCP 5.1.2)
After Effects 7
Shake 4Currently working on ‘Lookin’ For Lucky’
Feature Film for Albino Injun Productions.
http://www.lookinforlucky.co.uk
