Activity › Forums › Adobe After Effects Expressions › SourceRectAtTime for multiple lines hack?
Roei Tzoref replied 7 years, 4 months ago 4 Members · 14 Replies
Tomas Bumbulevičius
May 27, 2019 at 5:18 pmHey Roei,
yesterday I responded to your message with suggestions on how to improve your design, but it was removed due to the fact that I provided more insights about my template, like it would be a spam.. Oh well, lesson learned ☺
Anyways, to break down your current solution, I think its an interesting approach, yet there are few important things to think about. It is essential that such ‘boxed’ design would adapt automatically without a need to tweak paddings, etc. As otherwise, it looses the main purpose of easy update with different phrases. With that said, look for way to improve it from this point of view.
As for my design, I spent quite a lot of time to narrow it down to the point of re-usable template. There is no demo project to test it out, but if you want to have a look at what is possible to do with it – https://youtu.be/G-iy15R9H7s In case you have some questions about it, feel free to contact me directly. Cheers.
Find out more:
After Effects Tutorials: motion design, expressions, scripting.
Boxer – Dynamic Text Boxes Template with a Live PreviewSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Roei Tzoref
May 28, 2019 at 2:00 amThank you. I have a question about the limit in your template. why is there a 10 line limit?
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com -
Tomas Bumbulevičius
May 28, 2019 at 6:22 amThe limit of 10 lines is simply my choice to make it more robust and not to clog execution with redundant amounts of data. I don’t see a real reason where someone could use more than 10 lines of text, especially for dynamic social media posts. Its unlikely to use text appearances with loads of paragraph texts, which might go beyond.
Each line can contain as many characters as needed.
In the gif below, you can see that once the number of chars per line reaches certain threshold ratio, whole phrase scales down (its adjustable). Meaning, it also allows user to avoid having text reaching outside the boundaries of the comp size – which is super useful for adding phrases without worrying of extra size/lines tweaking. Also, growing of lines is possible from all 9 locations (top, center,bottom, left, center, right), combined cases.
Find out more:
Boxer – Dynamic Text Boxes Template with a Live Preview -
Roei Tzoref
May 28, 2019 at 1:51 pmThank you Tomas. this preset looks very good and efficient. if I need that sort of thing I will use it. I already posted it where there was a discussion about it ☺
Roei Tzoref
