Activity › Forums › Apple Final Cut Pro Legacy › Sound Mixer ?/FCP5 with an AJA IOLA box.
Pete Sake replied 20 years, 9 months ago 5 Members · 15 Replies
Pete Sake
December 31, 2005 at 1:13 amI’ll try for 1/4″
Maybe this is the mixer I should be getting. Not sure of the cost.
https://www.mackie.com/products/mcu/index.html
Peter -
Frank Nolan
December 31, 2005 at 6:17 amPeter that is not a mixer, it is a mixing control surface. It is really just an expensive mouse. There are no inputs for audio and no audio signal will pass through it. It is purely for controlling faders in your computer software program. Just hook up your mackie 1202 and as I explained and edit to your hearts content. If your are doing multitrack audio (like a lot of channels) in FCP and you want a control surface, to mix on the fly, then go for it. But from what you’ve said of your workflow so far that controller wont do you any good.
Andrew
December 31, 2005 at 9:03 pmthey(sony) have a add on that can give the 2800 4 channels of audio, lok on ebay I have seen them real cheap, i for get what there called but idf you look around you will see them, it’s just an add on to the top of the 2800.
Pete Sake
January 1, 2006 at 6:42 pmThanks Everyone for taking the time to help me as we take the plunge from M100 to FCP5
Audio Levals?
The Odb on my Mackie comes into FCP at approx -26db. You get -12 db (I get confused over the digital Odb and the Analog Odb.)
ALSO
Were not getting real time dissolves or real time by adding a second track gets a red bar.
We are in Safe RT. Capture input AJAlo la: YPb Pr Betacam US DV/DVCPRO.
2 gigs of RAM on a G52.7 /FCP5/ Betacam 2800
Best wishes for the New Year!
Peter
