Activity › Forums › VEGAS Pro › Sony vegas pro 13, only imports audio from .MOV files (PRORES 422(PROXY) 1920X1080 millions)
Nigel O’neill replied 8 years, 3 months ago 9 Members · 16 Replies
John Rofrano
November 17, 2014 at 1:17 pm[Bob Jordan] “you can try to convert MOV to a more editing-friendly format such as WMV or MPEG-2. “
Just FYI.. WMV is not an “edit-friendly” format and is one of the worst formats you can edit in Vegas Pro. Vegas can’t even read the audio in these files so it has to create audio proxies. Do not convert files to WMV to edit in Vegas Pro, it will just lead to other problems.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Red-rob Rothkopf
February 11, 2015 at 6:58 pmFYI — I just received my first footage from a BMD Cinema Cam and am having the identical problem. Audio imports, no video.
It was recorded using ProRes LT. It plays fine in VLC and other players. Vegas only imports the audio. Besides dragging it in, I tried “import media”… says it can’t understand the video format 🙁
Format : apcs
Codec ID : apcs
Duration : 24s 57ms
Bit rate mode : Constant
Bit rate : 102 Mbps
Width : 1 888 pixels
Original width : 1 920 pixels
Height : 1 062 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 1.699
Stream size : 293 MiB (98%)
Language : English
Encoded date : UTC 2014-01-31 18:51:03
Tagged date : UTC 2014-01-31 18:51:03 -
Red-rob Rothkopf
February 11, 2015 at 7:12 pmOOPS… installing QT 7 seems to have fixed my problem… sheesh.. so easy
John Rofrano
February 12, 2015 at 4:17 am[Rob Rothkopf] “OOPS… installing QT 7 seems to have fixed my problem… sheesh.. so easy”
I’m surprised that Vegas Pro imported the audio without QuickTime being installed. It usually warns you to install QuickTime. Glad you figure it out.
~jr
Ken Harbauer
May 29, 2018 at 2:16 pm…not sure if this helps at all, BUT you can always upload the .mov file to your YouTube account, then download what you just uploaded as an .mp4 file from your YouTube Creator Studio (the download option is under the Edit dropdown next to your video in the list). Not sure about quality downgrades, but at the very least the video will be there along with the audio.
Nigel O’neill
June 5, 2018 at 2:05 pm[manuel pimentel] “my head is about to explode, everything says I “Should” be able to play the file, but I Can’t, “
When I had this problem using footage from an iPhone, I used QWinFF to convert my MOV files to MP4. They imported fine then into Vegas.
My system specs: Intel i7 7700k 4.20 GHz, GTX570, 16GB RAM, Gigabye Z170 HD3, Vegas Pro 12 (x64), Windows 10 x64 Pro, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
