Sony Vegas pro 10 rendering problems
Jake Butson replied 14 years, 7 months ago 5 Members · 23 Replies
Thomas Roell
February 8, 2012 at 7:43 pm[John Rofrano] ” [Thomas Roell] “The 59.94fps is kind of important. It’s the only way I can come up with to deliver good quality 29.97fps progressive for the web, and 29.97fps interlaced for a DVD.”
It’s certainly becoming more and more popular. I don’t understand how throwing away every other frame could be better than shooting the correct number of frames in the first place but that’s just me. ;-)”
Well the rational is quite simple. The footage is fast moving sports footage. Shooting in 720p @59.94 progressive allows me to get high quality for online viewing by simply throwing away every other frame. That’s essentially the same as having shot in 29.97fps progressive to begin with. If I want to deliver content on DVD, then I get the best quality by using every other frame for an even field, and the next frame would be the odd field. This way I can get more temporal resolution.
John Rofrano
February 8, 2012 at 8:01 pm[Thomas Roell] “If I want to deliver content on DVD, then I get the best quality by using every other frame for an even field, and the next frame would be the odd field. This way I can get more temporal resolution.”
OK, so you’re saying that you can make both 30p and 60i out of the same footage. That’s interesting. I hadn’t thought of that.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Jake Butson
February 19, 2012 at 3:55 amI finally found a good comparison of what I was going for.
Look at this clip.
It’s been exported from sony vegas pro 10 with the deinterlacing method “blend fields.”
https://www.youtube.com/watch?v=z4XP4AtwEVk&feature=relatedThis clip is the same thing only it has not been exported with sony vegas pro 10.
https://www.youtube.com/watch?v=EeNx2RTCMuYSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
