SONY VEGAS + i7 2600K + 8GB RAM + NEAT VIDEO = SLOW RENDERING?!
Mikhail Petrushin replied 14 years, 4 months ago 6 Members · 18 Replies
Demetris Christodoulides
May 3, 2012 at 2:24 pmThank you, this indeed looks like a possible way to solve the issues…i’ll try and let you know. Generally speaking would adding +8gb/ram and a far better gpu change my overall processes’ speed drastically or is it money wasted ? What do you think? Thanks!
David Lightman
May 3, 2012 at 3:29 pmIf Neat Video is something you use on a lot of projects a faster GPU with CUDA support is definitely something that will speed up rendering times.
Here’s how they define the rendering speed upgrades in version 3:
https://www.neatvideo.com/news.html#Neat-Video-v3-2011-8-25
May 3, 2012 at 7:55 pmYeap, sadly because the hvr-hd1000e underperforms in low light conditions and i have to use max exposure, i often get high noise at night…
Thank you for the excellent input so far.
For the time being, i have 2 regular 7200rpm western digital sata2 drives and i am thinking of switching to:
2xssd hard disks, one for os (windows 7 x64) + program files, and one only for projects
+8gb ram = total 16gb ram
+gtx570You think i’ll gain considerable speed with these updates? They will cost me around 750 euros..
Mikhail Petrushin
May 3, 2012 at 11:30 pm> Version 3 is at least 2x as fast as V2 (2.6 etc) when only using your CPU
It’s not true.
The developers say: “The exact speedup factor can vary in the range x1.0-x2.5, depending on the filter and project settings”In my case (I work with 1080-50p) the speed is increased by 20% only (1.2 times faster). However, I use AMD CPU and do not have NVidia video card.
May 4, 2012 at 7:09 amWhat render times do you get (an example for instance) and to what format are you exporting ?
Mikhail Petrushin
May 4, 2012 at 7:25 amSource: 1080-50p
Output: 1080-50p, Mainconcept AVC, High Profile, 2 passes encoding, Avg Bitrate: 28Mbps
NeatVideo settings: Adaptive Filtration, Temporal Filter Radius = 2, Noice Reduction Amount: 100/70/40, High Quality Filtering, Hight Resolution, Sharpening: 50/20/10, Conservative. NeatVideo performance 1.93 frames/sec.NeatVideo filter is applied not for all fragments (~50% fragments).
~14 mins (~42000 frames) video was rendering for 11 hours in version 3.1 and 14 hours in version 2.6 (without my trick, for longer project I will try to use it) -
Mikhail Petrushin
May 4, 2012 at 8:24 amAMD Phenom 840, 8 GB DDR3 RAM, AMD 6850 Video, 7200rpm HDD.
The long render time is not exactly my problem.
https://www.neatvideo.com/nvforum/viewtopic.php?p=2658#2658Intel i7 2600, 3.4GHz, fast RAM — 6.4fps with radius=1. Intel i7 2600 is much faster then my CPU (and more expensive).
