Activity › Forums › DaVinci Resolve › Sony Oled calibration
Balázs Rozgonyi
January 9, 2013 at 5:42 pmI have testing some calibrations with my PVM-2541. Not the BVM series, but okay for locations.
Sony posted a ‘whitepoint setting app’ on its website. It takes a reading from a CA210, CS200, PR655, Klein, eye1 or other, and tries to match the monitor. The interesting thing is that the software ask you what are you matching to, and then applies a big offset. If you select CRT, it applies a -006/-0.011 offset which is pretty big.
But the biggest problem is apparently it needs an input – something – it cannot generate its own patterns, which is okay, but it does not tell you what to input. I suppose it has to be 100% white, as it takes the brightness down and measures dark grey from it, and then measures full white – but cannot tell. I tried it with 75% white and it was somewhat more off.
Anybody knows what the input pattern should be?
Balazs -
Pedro Conforti
July 30, 2014 at 3:48 amHi,
I’ve came across this step by step guide, which says the input image has to be 100% white. Could not check it since I don’t have a i1 Pro (only a i1D3), but here it goes anyway:
https://www.negativespaces.com/blog/2013/4/22/sony-oled-calibration.html
As an i1D3 and Sony PVW 2541 oled owner, I would really appreciate if someone could share any updated information about the offset values to be applied to this particular colorimeter to match my 2541 to a good old D65 CRT whitepoint… after many years of joyful colorgrading, since I bought the 2541 I feel cursed and very frustrated by this oled green cast thing! Still struggling to make it work with Lightspace CMS and give me back the WYSIWYG confidence I used to have with Sony CRTs!
Pedro
Pedro Conforti :: Colorist
pedroconforti.com
———————–MAIN SYSTEM
DaVinci Resolve v10.1.4.009
OSX 10.9.2 Mavericks
Hackintosh i7 3.69Mhz 32Gb RAM
GTX 780 + onboard video (GUI)
Tangent Element
Decklink HD Extreme 3DSYSTEM 2
Mac Pro 8 core 2.26Ghz 48Gb RAM
GTX 570 2.5Gb (macvidcards) + GT120 (GUI)
Euphonix MC Color
Decklink Mini -
Shahar Weinblut
August 24, 2015 at 5:41 pmHi
I am calibrating OLEDS (PVM’s,PVM-A), using i1d pro, which is the cheap 250$.
I use HCFR, and considering the limits of PVM series, the results are good.
Sony white balance app requires at least the i1 pro. I did not try it.2¢..
Weinblut Shahar
Engineering manager
Broadcast Video
http://www.broadcast.co.il
