Activity › Forums › Apple Final Cut Pro › Some FCP X Qs
  • Jeremy Garchow
    November 7, 2011 at 1:37 am
    So, squeeze seems to be an issue here?
  • Oliver Peters
    November 7, 2011 at 1:53 am
    “So, squeeze seems to be an issue here?”
    Yes and no. I think it’s a matter of how ProRes gamma is interpreted by programs other than Apple’s own. Clearly uncompressed is fine. I did another set of tests and ProRes to H264 through Compressor and as a Media Export is fine.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Jeremy Garchow
    November 7, 2011 at 2:25 am
    What OS are you using?
    I wonder if this has anything to do with those new codecs ?
    Have you downloaded these? https://support.apple.com/kb/DL1396
  • David Lawrence
    November 7, 2011 at 3:08 am
    [Oliver Peters] “Shoot! You’re right. I typed in a duration of 2 and didn’t actually check. Now I see that you can’t make the crossfade (dissolve) shorter than 3 frames. That’s what the result is even if you typed 2.”
    Yep, that’s what I get.
    2-frame dissolves are important! If you use them as much as I do, please make a feature request so I’m not the only one asking them to fix this.
    _______________________
    David Lawrence
    art~media~design~research
    propaganda.com
    publicmattersgroup.com
    facebook.com/dlawrence
    twitter.com/dhl
  • Tony Silanskas
    November 7, 2011 at 6:34 am
    For your first question, have you tried the “send to compressor” route and delete your render files before hand so it re-renders with whatever settings you choose in compressor? Not a fan of “send to compressor” as it crashes on me all the time and it’s slow but may get you uncompressed. Haven’t tested this though.
    tony
    http://www.HungryCliff.com
  • Oliver Peters
    November 7, 2011 at 12:34 pm
    What OS are you using?I wonder if this has anything to do with those new codecs ?
    10.6.8. And yes on the codecs.
    Oliver
    Orlando, FL
  • Oliver Peters
    November 7, 2011 at 12:37 pm
    [Tony Silanskas] “For your first question, have you tried the “send to compressor” route and delete your render files before hand so it re-renders with whatever settings you choose in compressor? Not a fan of “send to compressor” as it crashes on me all the time and it’s slow but may get you uncompressed. “
    I haven’t tried that but it should work. Kind of defeats the purpose though. 😉
    Oliver
    Orlando, FL
  • Oliver Peters
    November 10, 2011 at 1:17 am
    One “duh!” answer is to the “uncompressed” question. Set the project’s render format to “uncompressed 10-bit” and then export using “current settings”. The resulting exported file will be 10-bit uncompressed. No 8-bit option without going through Compressor.
    – Oliver
    Orlando, FL
Page 2 of 2
