Activity › Forums › Apple Final Cut Pro Legacy › Snow Leopard 101: For Smart People Only
David Roth weiss replied 16 years, 9 months ago 25 Members · 80 Replies
Jeremy Garchow
September 23, 2009 at 3:53 pm[Mark Slocombe] “is a ‘clean’ disk in this case one which is completely erased, then install OS then apps from scratch? “
Yes. Start with an empty and proerly formatted disk. Then install the OS and run software update. Then install all of your applications and run software update.
Make sense?
Jeremy
Mark Slocombe
October 2, 2009 at 10:33 amWe are backing up the boot drive via TimeMachine; does the TimeMachine BackUp work as a clone in terms of being able to boot from it?
Mark Slocombe
CreationVideo Ltd
https://www.creationvideo.co.uk -
Bob Cole
October 2, 2009 at 11:42 am[Mark Slocombe] “We are backing up the boot drive via TimeMachine; does the TimeMachine BackUp work as a clone in terms of being able to boot from it?”
No. Carbon Copy Cloner (and perhaps other programs) will create a bootable drive.
I think the received wisdom is to use TimeMachine often, to create incremental backups for the data on your drives, including your boot drive, and to use CCC somewhat less frequently, to create a bootable backup drive.
Bob C
David Roth weiss
October 2, 2009 at 4:26 pm[Bob Cole] “I think the received wisdom is to use TimeMachine often, to create incremental backups for the data on your drives, including your boot drive, and to use CCC somewhat less frequently, to create a bootable backup drive.
“That’s right! Bob’s been paying attention…
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Mark Slocombe
October 6, 2009 at 10:27 amIf I erase one of the 500gb drives that I use for media in my MacPro (keeping current boot drive as is) and install SL and FCS and plugins, and associated programmes on it, when I turn the MacPro on, will I get a dialog offering choice of boot drive or will I need to go into StartUp Disk and select the new SL/FCS drive?
Mark Slocombe
CreationVideo Ltd
Walter Biscardi
October 6, 2009 at 10:45 am[Mark Slocombe] ” when I turn the MacPro on, will I get a dialog offering choice of boot drive or will I need to go into StartUp Disk and select the new SL/FCS drive? “
If you hold the option key down when you turn on the Mac you’ll get the dialog to choose the startup disk.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Mark Slocombe
October 6, 2009 at 10:54 amCheers – and if I boot on the new drive, do I still see original drive and the media drives in Finder, and can share media on them to FCS on new drive?
Mark Slocombe
CreationVideo Ltd
Mark Slocombe
October 7, 2009 at 11:10 amHey David, Walter – would really appreciate advice on this (basic) question:
– and if I boot on the new drive, do I still see original boot drive and the media drives in Finder, and can share media on them to FCS on new drive?
Mark Slocombe
CreationVideo Ltd
Alexander Kallas
October 7, 2009 at 11:53 am[Mark Slocombe] “If I erase one of the 500gb drives that I use for media in my MacPro (keeping current boot drive as is) and install SL and FCS and plugins, and associated programmes on it, when I turn the MacPro on, will I get a dialog offering choice of boot drive or will I need to go into StartUp Disk and select the new SL/FCS drive?
“Only if you clone the boot drive first, and hold the option key on start-up.
Cheers
Alexander -
David Roth weiss
October 7, 2009 at 4:35 pm[Mark Slocombe] “- and if I boot on the new drive, do I still see original boot drive and the media drives in Finder, and can share media on them to FCS on new drive? “
The answer is yes. You can have as many boot drives as you want and if you boot to one the other boot drives show as normal drives and do your media drives. There’s nothing weird going on and nothing to be afraid of.
David Roth Weiss
Director/Editor
