Activity › Forums › Apple Final Cut Pro Legacy › small still photos in FCP composite look low-res
Pasi Koivisto replied 19 years, 5 months ago 9 Members · 16 Replies
Russell Lasson
April 14, 2007 at 7:49 pmIt seems silly to mention, but at the risk of seeming elementary, did you render your sequence after you brought the LiveType clip in?
Go to Sequence – Render All and make sure every option has a check mark by it.
Then select something in your sequence and select Sequence – Render All – Both.
Just thought I’d check.
-Russ
Rileym
April 14, 2007 at 9:00 pmindeed i did.
always a good idea to check that basic stuff, thouggh. just to be sure.i’m looking into render settings now.
but i don’t think thats it.
any other ideas?
thanks
Rileym
April 14, 2007 at 9:34 pmwell, when i said earlier that it was the livetype file causing the problem, i think that i was off base.
bringing the layers into a timeline by themselves, the photos look sharp, on the computer monitor, and my 2 external ntsc monitors, HOWEVER, as soon as i render, they get that loss in resolution that i’m talking about.
(earlier i was thinking, the photos look sharp until i place them over the livetype file, but i think the process of doing that was making the system do a proxy render which makes the photos lose resolution)
so it seems to be the video processing of the graphics that causese the issue, but i still don’t get it. why?
i haven’t had this issue before…any other ideas?
Tom Brooks
April 15, 2007 at 12:12 pmI’m having a similar problem but haven’t had the time to look into it yet. It looks like the photo clips are being poorly deinterlaced. Look for deinterlacing in your workflow.
Rafael Amador
April 15, 2007 at 1:17 pmIf the pictures got a lot of resolution and you are scaling them down if FC, you can get a lot of crap on it. Try to put 0.5 Gaussian Blur in the stills.
rafael -
Pasi Koivisto
April 18, 2007 at 7:37 pmWhy not try to put it all in a 8-bit uncompressed timeline and render it. I really don’t see a point in working graphics in a DV timeline unless you have to for delivery reasons but I seem to recall you’re going to deliver a wmv file.
https://kanalje.se – site in Swedish
