Activity › Forums › Adobe After Effects › Slowly morph 2D shapes using reshape
Carolyn Fusinato replied 20 years, 6 months ago 4 Members · 16 Replies
Ignatius Gorin
March 6, 2006 at 1:31 pmOk, I pretty much found my way through AE (5.5 here BTW) to apply your technique. Two things : I couldn’t find the template function, so neither could I lock it or hide it. When you say “This is a template: lock it” how do I tell AE that it is one (template) 😕 Also the version installed here is in French…
But it looks about ok, except one thing : aliasing on the circle edge… what I end up with here is useless due to that.
How could I do so the circle’s contour is smoother?
Thank you again.
Ignatius Gorin
March 6, 2006 at 1:37 pmOk I think I found the “lock” function, left of the timeline, along with video/audio/solo right?
Now I’m left with the aliasing problem.
TIA.
Ignatius Gorin
March 6, 2006 at 1:58 pm(…trying to find some kind of resample thing in AE, like Photoshop’s bicubic, since it’s Adobe, I still have hopes 🙂
Ignatius Gorin
March 6, 2006 at 2:15 pmOk, found it (anti-alias/quality toggle).
THANKS!-)
(… and I apologize as I know I’ve been kind of spaming this thread this morning)
Steve Roberts
March 6, 2006 at 2:40 pmI didn’t mean “template” as a technical term … sorry. I just meant that you should use it as the example when moving your mask points into position. You could make it a guide layer, I suppose.
Steve 🙂
Carolyn Fusinato
March 14, 2006 at 12:42 amit’s actually even easier than this
1. make a perfect circle mask by picking the circle mask tool clicking on the center of the comp & while dragging hold down the apple & shift keys. set a mask shape keyframe
2. move ahead in the timeline and click on “Shape” next to the “Mask Shape” attribute. In the dialog the comes up choose “Rectangle”
& that’s it….unless I’m missing something
-Carolyn
