Activity › Forums › Adobe Premiere Pro › Slow working Premiere Pro
  • Tim Kolb
    March 16, 2011 at 11:12 pm
    Well…of course there is an After Effects forum here at the Cow where you’ll find help very fast, but I suspect the issue is that your system is just plain starved for RAM so AE has to start disk-swapping instructions that should cache to RAM.
    If you want to run AE on a W7 64 system, I’d operate with 16 GB of RAM for CS5, but since you’re on CS4, I’d at least step up to 8 GB so AE can at least max out with the 4 GB it can use…right now you’re splitting up 4 GB of RAM between a resource-hungry OS and who knows what else.
    You’d probably also benefit from a display card upgrade for Open GL previews…that card appears to have been specifically designed for gaming.
    TimK,
    Director, Consultant
    Kolb Productions,
  • Reginald Emvula
    March 16, 2011 at 11:46 pm
    Thanks for the prompt reply,
    That does make sense, I had no idea I’d have to go 8gig + though!
    I’ve been searching for workarounds but that does seem like the most appropriate solution.
    Thanks again,
    Reg
  • Ananta Nepal
    August 21, 2011 at 12:22 pm
    I am having the same problem. Thank You Tim for an insight ! It definitely is a good one !
Page 2 of 2
