Activity › Forums › Apple Final Cut Pro Legacy › slideshow advice
  • Chris Poisson
    May 31, 2007 at 2:23 pm
    Hi Roger,
    Yes, quite impressive, at first glance anyway. As you say, perhaps a lot more than FM, I plan on trying the demo at least. My only concern is how easy is it to time to sound, music etc. Otherwise, I suppose with a little folder planning for separate sequences, overall a huge timesaver and creative tool in FCP. Thanks!
  • Eskatonia
    May 31, 2007 at 5:32 pm
    Regarding timing ImageFlow to music, it’s been designed that way. All the plugins in ImageFlow can use image timing as either “secs per image” or “BPM”. You can set the bpm of your music track and then set the images to be changing every four beats or every beat etc.
    I will also be adding some new options to take advantage of the audio analysis feature in motion 3 in a future version.
    –> [url]https://coremelt.com/[/url]
    Imageflow fx pack for Final Cut Studio, generate slide shows and motion graphics instantly from stills. <--
Page 2 of 2
