Activity › Forums › Adobe After Effects › Slicing a layer into boxes
  • Brian Charles
    January 9, 2010 at 3:35 pm
    Same as the previous example I uploaded, you need to copy the expression from the first layer and paste it to all other layers that you want affected.
    To see whether the expression is applied select the layer and press EE (that’s E twice) on the keyboard to reveal the expression.
    Make sure you have the Null and 2 sliders as in the example I uploaded.
  • James Hebert
    January 9, 2010 at 5:47 pm
    okay, awesome. except I when I go into edit I cant copy only expression to paste to all the others. tear
  • Brian Charles
    January 9, 2010 at 8:33 pm
    You need to select the opacity property for the layer with the expression then choose Copy Expression Only then paste.
Page 2 of 2
