Activity › Forums › Canon DSLR Cameras › “Skewing” elements in high speed movement
Bob Dix replied 14 years, 2 months ago 3 Members · 15 Replies
Christian Reid
July 10, 2012 at 3:13 pmHey Peter, don’t worry about the english, same problem here.
I know exactly what you’re saying about moving a piece of paper on a desktop scanner and about the slower shutter speeds causing more motion blur.
But what I don’t get is the reason why shooting in multiple numbers (1/60 at 30fps) gives me less rolling shutter than shooting 30fps at non-multiple shutter speeds, even when they are faster, like 1/160.
Pete Burger
July 10, 2012 at 3:28 pm[Christian Reid] “But what I don’t get is the reason why shooting in multiple numbers (1/60 at 30fps) gives me less rolling shutter than shooting 30fps at non-multiple shutter speeds, even when they are faster, like 1/160.”
I wasn’t aware of that. Doesn’t make any sense to me either… Hmmm… Have to try that myself.
“Tragedy is a close-up; comedy, a long shot.” – Buster KeatonMe on Twitter (english/german)
https://twitter.com/FastFoodVideo -
Bob Dix
July 11, 2012 at 6:30 amChristian,
Some time ago Canon Service advised that to get the smoothest result out of the Canon 5 D Mark II set the shutter speed at 1/50 sec, PAL which is 25fps.However ,in bright sunshine the image could be overexposed, you may need to go to 1/125 sec or higher, check the LCD. Also, check this out > :https://www.videomaker.com/article/10418/2/It appeared to improve the smoothness of the video.
For tape camcorders the default speed is normally, 1/50 or 1/60 sec
But, recently I needed to throw the background in video out of focus by using F/5.6 and speeds in some cases went as high as 1/2000 sec, Frankly I could not fault the smoothness of the video at any speed ? And that certainly gets rid of any dust spots on the sensor ?
This is also worth a look > https://www.canon5dtips.com/the-basics/what-is-the-best-shutter-speed-for-movie-mode/
Freelance Imaging & Video
AUSTRALIA -
Christian Reid
July 15, 2012 at 3:41 pmHey guys, thanks very much for the assistance.
I’ve made some testing yesterday and the rolling shutter effect has indeed been reduced with my settings to 1/60 at 30fps. And I tested on a FAST subject, an Audi R8 LMS! Really cool…hehe
I hope it fixes my problems from now on, but it is also true that narrowing your stops options to just 1/30 and 1/60 certainly is a pain when you get an overexposed scene. Had the chance to test that also. You were right Bob!
Thanks again, Chris
Bob Dix
July 16, 2012 at 12:21 amThat’s good, not right all the time, have a win now and then
AUSTRALIA
