Activity Forums Broadcasting Single Mode Fiber Issues
  • Mike Thomson
    April 24, 2016 at 4:56 am
    The equipment used for communications over multi-mode optical fiber is less expensive than that for single-mode optical fiber. Typical transmission speed and distance limits are 100 Mbit/s for distances up to 2 km (100BASE-FX), 1 Gbit/s up to 1000 m, and 10 Gbit/s up to 550 m.
    Also I found this company QuestTel they have full scope SDI OVER FIBER products single mode
  • Adam Michnik
    July 8, 2016 at 9:03 pm
    This is not completely true and i do not think is entirely about HD/SD/3G-SDI over fiber, but Ethernet over products, especially singlemode 1310nm is as cheap as multi-mode 850nm, there a positives and negatives to using multi mode versus single mode fiber optics.
    Multi-mode has less bandwidth but it does not effect SDI signal,
    There is devices on the market that use unique adaptive technologies, it allows you to use either fiber you want for SDI optical transport.
    SDI fiber extender https://thorbroadcast.com/sklep-240/produkt-222
    It’s also possible to multiplex different signals such as Ethernet, base-band video, and RS-control(232/485) with the same HD-SDI signal. There’s a lot more to this than you thought 🙂
Page 2 of 2
