Activity › Forums › Sony Cameras › simple question
  • Deleted User
    March 2, 2011 at 8:31 pm
    Ok, thanks. It seems strange to me that shooting at a lower res or framerate doesn’t change the file size. If the bitrate is the same for 720 as it is for 1080, shouldn’t that mean a higher quality image in 720 since there’s more data per pixel? If not, does anyone know why that is? (I’m just curious about this)
    Black Friar Productions
    Denver, Colorado
  • Don Greening
    March 2, 2011 at 8:36 pm
    Shooting EDCAM EX codec 270p 30 plus 48k 16bit audio 2 channels adds up tp 7.7Gbytes of space per hour. Keep in mind that the EXCAM EX codec only needs 20% more space than Mini DV or HDV.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Bob Tompkins
    March 3, 2011 at 11:50 am
    I get 113 minutes per 32GB SDHC card.
  • Clint Fleckenstein
    March 3, 2011 at 2:50 pm
    “I’ll be shooting about 2.5 hours of footage on 4 cameras so I’m trying to budget space”
    One thing you’ve probably read on this forum is to keep your BPAV folders intact as your camera masters. It’s very important that you archive these files as you would a master tape.
    Rewrapping to MOV for Final Cut Pro only gives you files that work in FCP. If you have to hand footage off to a different editing system, and all you have is the MOVs you wrapped for Quicktime and not your original BPAV folders, you are in the proverbial “hurtlocker.”
    Cf
  • Deleted User
    March 3, 2011 at 6:54 pm
    “One thing you’ve probably read on this forum is to keep your BPAV folders intact as your camera masters. It’s very important that you archive these files as you would a master tape.”
    So right… I learned that the hard way!
    Denver, Colorado
  • Brent Dunn
    March 4, 2011 at 9:11 pm
    You will use the log and transfer plugin for final cut. If you haven’t done this upgrade, it is available for free. You won’t have to use the Sony transfer software.
    If you transfer your card onto a hard drive, then do the log and transfer to another drive (scratch drive) you will have files on both drives taking up space.
    Before, you had to convert them to ProRes and it was about 1 Gig per minute. With the new Final Cut you can use a light version of ProRes which will save you space.
    Try to keep your scratch disc clear except for your project, if you have a 1-2 TB drive, and you should be fine.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
Page 2 of 2
