Activity › Forums › Blackmagic Design › Shuttle 2???
Bo Skelmose
February 7, 2012 at 8:37 pmHi – just downloaded the new version of calibrated MXF and it WORKS.
I will buy it when I got a new computer so I do not lock it to my old computer. It seems there is four resets of the software so you can change something on the computer 4 times and then the software ends. I had so much bad experience with this and windows so I will wait until I got a never system. -
Greg Booth
February 7, 2012 at 11:00 pmHi Bo,
Cool – glad our new release can help out your workflow!
The new v2.2.0 release does have BETA support for BlackMagic Design DNxHD MXF files captured by HyperDeck devices. Also there is a new section entitled ‘dnxhd options’ in the Calibrated{Q} MXF Import User Guide that explains DNxHD workflows in applications (like FCP or AE/PPro) that use Calibrated{Q} MXF Import to import DNxHD MXF files. The section is a little long since we’re trying to fully explain in a simplified way a somewhat complicated workflow. I would strongly suggest reading over the section to see how to properly setup Calibrated{Q} MXF Import for any DNxHD workflow.
The ‘dnxhd options’ section could also help people working with DNxHD .MOV files too in FCP, as the section tries to explain the reasons for color shifts when using DNxHD in FCP. You can download the PDF User Guide in this link User Guide
Cheers,
GregCalibrated Software
Bo Skelmose
February 13, 2012 at 10:26 pmHmm – just tried the audio and it is not there. As stated in the manual 24 bit audio cannot be seen from premiere by the use of the software. Loading of the clips by restarting the project takes a long time without premiere stating whats going on. Hope this will work in the final version.
