Activity › Forums › Adobe Premiere Pro › Setting up a RAID array For Dummies (Me)
  • Duke Sweden
    April 28, 2016 at 9:55 am
  • Tero Ahlfors
    April 28, 2016 at 11:41 am
    You don’t have to clone your whole drive with the sync tools. You can also set up certain folders to be synced. I have my projects and photos set up to be synced once in a while to an external drive.
  • Duke Sweden
    April 28, 2016 at 2:00 pm
    Oh, ok. I’ve got one of those. But again, as you saw above, I’m not exactly making movie history over here 😉
  • Duke Sweden
    April 28, 2016 at 2:06 pm
    Box just came. Time to tweak!
  • Duke Sweden
    April 29, 2016 at 2:30 am
    Un-freakin’-believable. This one was worse than the other one! At one point, while I wasn’t even touching it, it went into chkdsk mode, took 20 minutes to check the hard drive for errors, then went into reboot and stayed in reboot for another 30 minutes! Took 194 minutes to install Premiere Pro! Then, when I had it finally running, I would click on a dropdown, and nothing would happen for like 15 seconds, then it would drop down, I’d click on my choice, and it wouldn’t change for 10 seconds! Plus it already had Chrome installed (!?!), but it was an outdated version which wouldn’t let me update it. And when I turned it on it would always try to boot from the optical drive first.
    Needless to say it’s going back. I’m done with workstations. I know they’re NOT supposed to be this bad, but I’m just soured on the whole thing. I’ll just have to find ways to put my rendering times too good use.
    On the bright side you won’t have to deal with my inane problems anymore.
Page 3 of 3
