Activity › Forums › Apple Final Cut Pro Legacy › Serious Project File Corruption in FCP 5.0 and FCP 5.0.2
Walter Biscardi replied 21 years, 2 months ago 6 Members · 12 Replies
Mitch Ives
August 5, 2005 at 4:04 pm[Chris Tomberlin] “Plus, there are some real problems with the 10 bit codec right now. Do search in the After Effects and Blackmagic forums and you’ll see what I mean…”
What did they change… it was working fine before?
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.com
http://www.insightproductions.com -
Walter Biscardi
August 5, 2005 at 10:31 pm[Walter Biscardi] “I think it’s definitely some sort of a buggy still frame thing that has not been solve in FCP 5.0 and want to run some tests to see how easy / hard it is to set off this issue.”
I can confirm that this is definitely a bug. Even with Memory Cache set to 50% (1GB) I got the issue again today when I was trimming a Nest in a sequence. Got the red screen, got the “Not Found!” error followed by the “Out of Memory” Error. Quit FCP, Trashed Prefs, Reset the Memory Cache to 50%, re-opened my project and all was well.
Will test soon and see what exactly will make it trip.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
