Activity Forums Adobe After Effects Expressions Self – Resize a Bezier Path Shape Layer to Comp size and more
  • Self – Resize a Bezier Path Shape Layer to Comp size and more
    Posted by Nick Mara on September 27, 2020 at 6:11 pm
    Hey Folks,
    I’m trying to create a frame that automatically adjusts its size to the size of any composition.
    I’ve already opened a discussion and I collect enough informations to create a new complete thread I hope.
    This is the other discussion:
    https://creativecow.net/forums/thread/resize-a-mask-path-or-a-converted-bezier-path-shape-layer-to-comp-size/
    Returning to us…
    The frame I’ve is a Rectangular Shape Layer converted to a Bezier Path.
    I’ve added a Stroke on the rectangle in order to create the frame border and I’ve also added a Trim Path to access the Start and End animation parameters.
    The main problem is that I would like to use this expression on the End property of the Trim Path:
    linear (time, 0, thisComp.duration, 0, 100);
    With this expression, the rectangle’s stroke automatically build itself from 0 to 100 based on the composition duration.
    At this point I would like to have the possibility to change the size of the composition and consequently scale the size of the Shape Layer automatically to comp size.
    In order to do this, Dan Ebbert recommended me to apply this expression to the Path property of the Shape Layer:
    p = thisProperty;
    r = sourceRectAtTime(0,false);
    pts = p.points();
    newPoints = [];
    for (i = 0; i < pts.length; i++){
    newPoints.push( [pts[i][0]*thisComp.width/r.width,pts[i][1]*thisComp.height/r.height]);
    createPath(newPoints,p.inTangents(),p.outTangents(),p.isClosed())
    The expression works but when the Trim Path End value ​​is less than 50% or the Trim Path Start value ​​is greater than 50%, the Shape layer begins to expand:
    https://www.youtube.com/watch?v=FmgrOoaovRM
    The last thing I would like to do is to be able to change, using a Slider Control on a Null object, the initial vertex from which the frame begins to build up.
    In order to do so, I found an effective method that allows you to create Keyframes together with an expression that allows you to use them as options.
    Here the steps:
    I select the top left vertex of the Shape Layer and make a Keyframe on the Path property.
    I move forward on the Timeline with the cursor, I select the top right vertex of the Shape Layer and I make another keyframe.
    Likewise for the other two vertices.
    At this point I create a Null Object and apply a Slider Control on it.
    Last step is to add this expression to the Keyframed Path property and connect the Slider Control to the expression:
    n = Math.round(thisComp.layer(“NullObject_Name”).effect(“SliderControl_Name”)(“Slider”));
    n = clamp(n,1,numKeys)
    valueAtTime(key(n).time);
    Now it will be possible to change the starting point of the building up frame using the Slider Control, with the values ​​1, 2, 3 and 4 (as many options as the keyframes).
    https://www.youtube.com/watch?v=t8OtXayvOYc
    I realize that there are many functions that should work together on a single Path property with a single expression but I would like to understand if there is a way to link them all together or if there’s an alternative way to do so.
    I hope I was clear enough.
    Thanks in advance
    Resize a Mask Path or a converted Bezier Path Shape Layer to Comp size
    Andrei Popa replied 5 years, 11 months ago 2 Members · 29 Replies
  • 29 Replies
  • Andrei Popa
    September 28, 2020 at 9:14 am
    Hey. Add this to your path property. The path should be at position [0,0] with anchorPoint [0,0] and the layer in the middle of the composition(double clicking on the rectangle tool creates just this)
    cW = thisComp.width;
    cH = thisComp.height;
    corners = [[-cW/2,-cH/2], [-cW/2,cH/2],[cW/2,cH/2],[cW/2,-cH/2]];
    startCorner = 2;
    p1 = corners.splice(0,startCorner-1);
    corners = corners.concat(p1);
    createPath(corners)
    startCorner should be linked to your effect on the null(the one you want to control the start point with, obviously :D)
  • Andrei Popa
    September 28, 2020 at 4:13 pm
    I just watched the way you create your rectangle. That works too in this case but double clicking on the rectangle tool would save you some seconds 😀
  • Nick Mara
    September 28, 2020 at 6:12 pm
    Andrei Popa WOW!!!
    Thank you so much for your help.
    The expression you provided me works very nicely.
    Now if I resize the composition, the Rectangle resizes itself and most important, the starting point of the path can be easily chosen via the slider control !
    Amazing!!!
    Can I ask you another question?
    The slider control now works within the range which goes from 2 to 5.
    Each number it’s equal to a corner point starting from number 2, which refers to the Bottom left corner.
    If I input a parameter of 0 or 1 an error occur.
    Is there a way to shift that range of a -1 value and lock the slider range ?
    I mean:
    Number 1 = Bottom right corner
    Number 2 = Bottom left corner
    Number 3 = Top right corner
    Number 4 = Top left corner
    I hope you could assist me again.
    Thanks in advance for you time and for you priceless help =)
  • Nick Mara
    September 28, 2020 at 6:27 pm
    <div>
    Rofl That’s so true, I used to go with the double-click but then something happened in my life and now I’m going this way Rofl
    Thanks again Andrei !!
    </div>
  • Andrei Popa
    September 29, 2020 at 10:29 am
    I added a slider control to the layer.
    This works for me with a slider with values 1-4 but other order than you said.
    startCorner = effect("Slider Control")("Slider");
    createPath(corners)
    This is to make the order as you wanted it
    cOrder = [2,1,3,0];
    p1 = corners.splice(0,cOrder[startCorner-1]);
    createPath(corners)
  • Nick Mara
    September 29, 2020 at 10:57 am
    Andrei, thanks again !!
    I understood why the expression was not working for me.
    My project setting for the Expressions was set to Legacy ExtendScript not to JavaScript.
    Is there a way to turn this expression working in Legacy ExtendScript?
    In Legacy ExtendScript the expression it’s working within the range of 1-3.
    I also had to reorder the numbers of the cOrder to make it change the starting point clockwise like:
    cOrder= [1,2,3,0];
    If I input the number 0 or 4, an error occur.
    Is there a way to make like a sort of loop?
    I mean, is it possible to increase the number of the slider control and make the first chosen point always changing per each value in round?
    For Example:
    0 = First point
    1 = Second point
    2 = Third point
    3 = Fourth point
    4 = First point
    5 = Second point
    6 = Third point
    7 = Fourth point
    8 = ……………….. and so on
    Thankssssss
  • Andrei Popa
    September 29, 2020 at 11:24 am
    Ok, try this for your path
    startCorner = effect("Slider Control")("Slider").value%4;
    cOrder = [2,1,3,0];
    p1 = (startCorner == 0) ? [] : corners.splice(0,cOrder[startCorner-1]);
    createPath(corners)
  • Nick Mara
    September 29, 2020 at 1:37 pm
    SUPER !!!
    This expression works like a charm !!!
    I’ve seen that you also answered me on my other discussion:
    https://creativecow.net/forums/thread/i-need-help-with-this-expression-lineartime-0-thiscomp-duration-0-100/
    So what I want to tell you is that the expressions you provided me are working well with some adjustments.
    I created a video to show you from start to end the entire process, pointing out some “bugs” I found:
    https://www.youtube.com/watch?v=6Cw9oE0tAiQ
    Tell me If I’m doing something wrong.
    Anyway the problem now is that there are two functions working together:
    1 The”Start_Point” Slider Control which controls the starting point of the Path.
    2 – The “End_Point” SLider Control which controls the ending point of the Path.
    These are the changes I’ve made to the expression:
    Path expression:
    1 – cOrder=[1,2,3,0]
    Now it’s rotating anticlockwise one step to another, that’s perfect.
    End expression:
    1 – percentL = 50.5 * L / (L + l);
    percentl = 50.5 * l / (L + l);
    If I leave the value of 50, as you suggest (which should work perfectly), at the end of the path a little gap remains uncovered. So I’ve tried to add an extra 0.5 % and it seems to work.
    2 – shortPoints = [0, 4];
    With the range [1,4] something weird happened as you can see from the video but with [0,4] everything it’s good.
    That said I need to point out another issue.
    There is a sort of “bug” which is not a real “bug” but it’s annoying:
    The whole process works well when you first choose the starting point and then you change the end point.
    But if you first choose the End Point and then the Starting Point the stroke shifts.
    It’s pretty tricky to explain but you can see what I mean at the end of the video.
    Is there a solution for that?
    Thanks again
    I need help with this Expression: linear(time, 0, thisComp.duration, 0, 100);
  • Andrei Popa
    September 29, 2020 at 2:19 pm
    “1 – cOrder=[1,2,3,0]” this does nothing. It works anticlockwise without this.
    The rectangle does not complete because the last frame in the composition is invisible. You should subtract a frame from linear in order to fix this, not add to the percentage.
    linear(time, 0, thisComp.duration-thisComp.frameDuration, 0, theEnd)
    And you have to change those numbers for corners because you described it wrongfully in your post. You said in this order: bottom right, bottom left, top right, top left(it was bottom left, bottom right etc.). It actually was more complicated to me to do it the way you described it.
    All in all, this should work now:
    startCorner = thisComp.layer("Null 1").effect("Start_Point")("Slider").value%4;
    p1 = (startCorner == 0) ? [] : corners.splice(0,startCorner);
    createPath(corners)
    function arrIncludes(arr, element) {
    for (var i = 0; i < arr.length; i++) {
    if (element == arr[i]) return true
    return false;
    L = thisComp.width;
    l = thisComp.height;
    percentL = 50 * L / (L + l);
    percentl = 50 * l / (L + l);
    beginPoint = thisComp.layer("Null 1").effect("Start_Point")("Slider").value%4;
    stopPoint = thisComp.layer("Null 1").effect("End_Point")("Slider") % 4;
    shortPoints = [0, 2];
    firstLInstances = Math.ceil(stopPoint / 2);
    if (arrIncludes(shortPoints, beginPoint)) {
    theEnd = percentl * firstLInstances + percentL * (stopPoint - firstLInstances);
    } else {
    theEnd = percentL * firstLInstances + percentl * (stopPoint - firstLInstances);
    theEnd = theEnd == 0 ? 100 : theEnd;
  • Nick Mara
    September 29, 2020 at 2:50 pm
    THIS IS AWESOME !!!
    Now everything is working perfectly =)
    I’m so sorry I’ve described the order of the corners wrongfully in the post.
    All the issues are now solved and so I have my last question:
    Is it possible to add a Checkbox Control to the expression able to invert the Path direction?
    I mean:
    Checkbox ON = The Path’s direction goes anticlockwise
    Checkbox OFF = The Path’s direction goes clockwise
    I can’t thank you enough for helping me !!!
Page 1 of 3
