Activity Forums Adobe Premiere Pro Ripple delete captions
  • Ripple delete captions
    Posted by Bob Woodhead on November 15, 2020 at 12:17 pm
    Not a PPRo editor, FCPX myself, and though I’ve searched I can’t find the answer to whether it’s possible to ripple delete captions along with video. Goal is to keep captions synced when editing an already-captioned video.
    I’ve got a project that’ll be edited on both PP & X, and this workflow needs to work on both. I’ve tested on X, it’s easy there.
    Eric Santiago replied 5 years, 10 months ago 5 Members · 14 Replies
  • 14 Replies
  • Eric Santiago
    November 16, 2020 at 12:37 am
    The caption is attached to the Primary Storyline in FCPX which is not the same in Premiere.
    Love FCPX for that.
  • Bob Woodhead
    November 16, 2020 at 12:54 am
    Right, Like I said, I’m a FCPX editor, so I’m familiar with it’s methods. Looking for the PPro capabilities re: caption ripple edits.
  • Eric Santiago
    November 16, 2020 at 2:00 am
    I just tried a few things and nothing that easy.
    The only way to keep them to a clip is to subsequence/nested.
    Not fun.
  • Andreas Kiel
    November 16, 2020 at 9:38 pm
    PPro uses a caption stream (track) connected to nothing opposed to FCP which uses independent captions connected to a clip (of whatever type) plus a lane/role.
    The only thing you make it somehow comparable – in regards of workflow – is to use “Titles” instead of captions.
    If you are on Mac OS you may try my premiereTitles (http://www.spherico.com/filmtools/TitleExchange/PTI/index.html)
    This way you can keep working with FCP SRT – if you want – and keep those in sync with Essential Graphic Titles in PPro.
    Once finished you can convert the PPro titles to SRT if needed.
  • Eric Santiago
    November 16, 2020 at 10:17 pm
    But if they are titles you still need to attach them to a clip.
    I believe the question was to keep the CC attached to a clip while editing at all times.
    Maybe I got that wrong?
  • Bob Woodhead
    November 16, 2020 at 10:27 pm
    Interesting, Andreas. So if I read you correctly, the fundamental answer to my OP is ‘no’ – captions don’t ripple delete along with the rest of the timeline. But your tool allows ’round tripping’ to/from SRT and PPro titles. So a workaround almost as good as native, and if things go well, a few more sales for you. 🙂
    Not exactly clear on your post Eric, but all I’m looking for is simply to be able to ripple edit a timeline, and have the captions (titles, with Andreas’ tool) ripple as well.
    Thanks for the info!
  • Eric Santiago
    November 17, 2020 at 2:12 am
    I must have misunderstood your post.
    I thought you wanted to be able to ripple a clip and have the CC follow it similar to FCPX.
    As I stated, I got that to work by using a SubSequence/Nested type of process.
    My bad if that’s not what you were trying to achieve.
  • Andreas Kiel
    November 17, 2020 at 3:11 pm
    Eric,
    You are right. But PPro uses a “real closed caption track”. So every edit you make – like deleting a clip – has to be done to the CC track upfront.
    Using EG titles though will allow a ripple delete, still not that elegant and safe(!) as with FCP.
  • Eric Santiago
    November 17, 2020 at 3:18 pm
    Ive done a ton of CC (docs and features) using both PPr and FCPX.
    There is no easy out but thanks to the EG Titles, I will give that a try soon.
    I have never done CC before final edit and I dont plan on it ever 🙂
  • Andreas Kiel
    November 17, 2020 at 3:25 pm
    “I have never done CC before final edit and I dont plan on it ever “
    Not such a bad plan 😉
