Activity Forums DaVinci Resolve Resolve 9, PC and Prores render
  • Jimmy Christensen
    June 13, 2012 at 6:30 am
    You might want to check out ffmbc which is probably better at creating metadata.
    https://code.google.com/p/ffmbc/
  • Dan Moran
    June 13, 2012 at 11:04 am
    Apple own Prores so its totally up to them. It makes sense for them to keep ProRes a Mac only render codec for Resolve as it means people will have to buy a MacPro rather than building a Windows box.
    The option I use is we have Linux systems for the speed and then two mac systems in our machine room for ingesting and rendering anything thats ProRes. Works really well as the main suites are always grading.
    Dan Moran
    Colourist
    Smoke & Mirrors: London
    http://www.danmorancolor.com/blog
  • Timo Teravainen
    June 13, 2012 at 11:38 am
    Is there a gui front-end for ffmbc? For ffmpeg, I’ve been using AnotherGUI, it has presets for prores.
  • Jimmy Christensen
    June 13, 2012 at 11:42 am
    You can most likely just replace ffmpeg.exe with ffmbc.exe
    Edit:
    They actually mentions it on the AnotherGUI website :
    “ffmbc vs. ffmpeg
    ffmbc has several proffessional exhangements like target IMX, target DNxHD and supports mapping audio cahannels. The latest one makes possible to create elementary streams with every audio channel in separate file.”
  • Timo Teravainen
    June 13, 2012 at 11:43 am
    Dan, do you render DPX intermediate from Linux systems?
  • Chris Kenny
    June 13, 2012 at 2:16 pm
    [Jimmy Christensen] “You might want to check out ffmbc which is probably better at creating metadata.
    Yeah, should have been more specific. That’s what I’m using.
    And a quick update: I’ve got it embedding timecode and reel names that Resolve can read correctly.
    Digital Workflow/Colorist, Nice Dissolve.
    You should follow me on Twitter here. Or read our blog.
  • Robert Houllahan
    June 14, 2012 at 5:16 am
    So with multiple Linux Resolve machines do you run a Mac-Pro as a Pro-Res render station sort of like Baselight Compressor? And if so do you just share the database and open the project (with shared media) in the OSX machine only to render Pro-Res?
    i.e. Prores as the last reason to run OSX?
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma. Light-Space CMS + Hubble
  • Juan Salvo
    June 15, 2012 at 5:10 am
    Actually in linux ffmpeg has reversed engineered the ProRes codec (444 doesn’t work so well) so while I don’t think you can make ProRes out of the box.. you can make a dpx sequence or something, and then convert to prores on the linux station.
    Online Editor | Colorist | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Bradley Stuckel
    June 24, 2012 at 7:57 pm
    PRORES encoding!… on Windows would be fantastic!
    Does anyone know where to find the Davinci Resolve 8.2 beta 3 version which supports prores encoding???
    If not does anyone have the prores enables resolve setup file still that they are willing to share?
  • Juan Salvo
    June 24, 2012 at 11:12 pm
    It was pulled shortly after release.
Page 2 of 3
