Activity › Forums › DaVinci Resolve › Resolve 12.5 message: “GPU memory is full”
Dmitry Kuznetsov replied 8 years, 10 months ago 7 Members · 16 Replies
Tero Ahlfors
October 8, 2017 at 6:42 pm[Duke Sweden] “So there is no way to export true C4K from Resolve, something that Premiere Pro/Media Encoder do with no problem?”
There is a way: Get a new (or used) GPU that has enough VRAM for what you want to do. Resolve works differently under the hood than Premiere or AME.
Duke Sweden
October 8, 2017 at 6:49 pmI just bought this card. I’ll just find more workarounds.
Cheers.Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
Premiere Pro CC 2017 v.11.0 -
Chris Wright
October 9, 2017 at 6:05 amand btw, how did a resolve thread end up in the adobe media encoder forum? did adobe buy out blackmagic design, lol?
Tero Ahlfors
October 9, 2017 at 6:08 am[Chris Wright] “and btw, how did a resolve thread end up in the adobe media encoder forum? did adobe buy out blackmagic design, lol?”
There’s probably some sort of “someone mentioned a piece of software let’s add this to that forum as well” thing going on in the backend.
Glenn Sakatch
October 9, 2017 at 3:08 pmDuke, I wouldn’t call this the idiots way, I would call this the smart way.
There is very little need to “work” at 4k. I routinely set my timeline to HD, do my work, then switch it back to 4k for the final renders. If you are pulling keys that require the 4k source, then switch over, but I would suggest 95+ percent of your color work can be done in hd with a final switch to 4k prior to render. Even outputting client approvals can usually be HD. In fact my last 4 projects were shot at either 4k or 2.8k, and didn’t see the source resolution until final render, except for the day of VFX plate outputs, where the timeline was set to full res.
I have a preset ready to go for 4k, 2.8k and HD and it takes about 5 seconds to switch from 1 to the other.
And yes, you do need to set your timeline resolution to 4k prior to rendering, otherwise you are upconverting from your timeline resolution to your output resolution.
As for your black bars issue, you need to look into the image scaling settings and play with the scale with crop vs scale to fill screen vs force all the corners settings. In there you will find your ability to get rid of the letterbox, while maintaining aspect ratios.
Glenn
Dmitry Kuznetsov
October 27, 2017 at 8:04 pmIf you need a little bit GPU RAM space you can set Proxy Mode to Quarter Resolution, Delete Rendered Cache, then reopen Resolve and start export. Right after start click minimize Resolve window, until it finished.
Color Grading Specialist / DI Colorist / DaVinci Resolve Colorist
For business inquiries:
https://contact.photodmitry.com
