Activity › Forums › Adobe After Effects › resolution issue
resolution issue
Posted by Greg Strange on June 2, 2005 at 9:15 pmI’m working in DV. I capture using FCP. When I import to AE my clips look low res. Pixelated. Ugly. The files I capture in FCP look great in FCP but the same ones look terrible in AE (this is true whether I import a self-contained QT exported from FCP, a reference movie out of FCP, or even the actual captured QT movie itself imported directly into AE).
My settings in AE is the preset, DV 720 x 480. The layer quality is set to “best” and the resolution is set at “full” in the composition settings. What am I missing? This is driving me crazy. Can someone please help?
Mark Cookman replied 21 years, 3 months ago 5 Members · 12 Replies -
N. Row
June 2, 2005 at 11:09 pmOpen the movie in the QTPro player. It must be the “Pro enabled” quicktime. If I remember correctly you “Get movie Properties” for the video track and then set “Quality” to high. Save and re-import.
This might do the trick. This does’t happen with .mov’s from an Avid however. I feel is a little bit of a dirty trick for Apple to require you to repurchase Quicktime to enable you to have to resave all the exported QTs you may deal with.
If I’m wrong on this, I apologize, Apple!
Greg Strange
June 3, 2005 at 6:35 amFirst of all thanks for your tip.
I have QT Pro. I opened my clip in QT player and clicked “high quality” in the settings and the image unmistakably became sharper. I re-saved, giving my clip a different name, saving it as a self-contained movie. I couldn’t wait to import into AE and when I did, crap! It looks exactly like it did before–soft, aliased edges–terrible!
Again, the layer quality is set to “best” and the composition’s resolution is set to “Full”.
Here’s the real kicker. When I double-click on the imported clip in the project bin, the clip opens up in a footage window and it looks beautiful, crisp and clean, like it’s supposed to. But as soon as I drag it to the composition–aaaahhh. Ugly.
Anyone? Help, please!
Greg Cotten
June 3, 2005 at 4:27 pmI have some advice…. use DV AVI!!!!! Actually, I’m not sure… does FCP support DV AVI? I don’t understand why you are using a extremely lossy codec… or are you using MJPEG compression at quality 100% or something like that? Someone please inform me!
-Greg
Greg Cotten
June 3, 2005 at 4:35 pmI have some advice…. use DV AVI!!!!! Actually, I’m not sure… does FCP support DV AVI? I don’t understand why you are using a extremely lossy codec… or are you using MJPEG compression at quality 100% or something like that? Someone please inform me!
-Greg
Steve Roberts
June 3, 2005 at 5:19 pmDid you switch off Pixel Aspect Ratio Correction in the comp window? It makes videos look a little rougher, so it should be switched off before rendering for best quality.
Steve
Greg Strange
June 3, 2005 at 6:31 pmI’m using FCP’s built-in codec for DV. It doesn’t offer any choices for codecs. Besides, that doesn’t explain why my clip looks good in FCP and poor in AE.
Greg Strange
June 3, 2005 at 6:36 pmYes, pixel aspect ration is off. Turning it on or off seems to have no effect on the image. I was hoping it was something simple like that but AE doesn’t really offer much in terms of settings for quality/resolution.
If anyone is willing, I’d love to send a small clip and see if you have the same resolution issue in AE that I’m experiencing.
Mark Cookman
June 6, 2005 at 1:57 pmDid you sort this yet:
have you tried dragging the footage onto the “create new comp” icon in project window?
How did the render turn out even with duff previews ? -
Greg Strange
June 6, 2005 at 4:50 pmNo I have not figured it out yet. I check my mail every day to see if I have anything from Creative Cow. This is killing me.
I tried your suggestion, dragging the footage to the “create new comp” icon. This made no difference. The preview is poor as well as the render.
I’m going to start a new thread with a screencap to see if someone can pinpoint my problem. Thank you for your input though. Here’s the screen cap, 100% to scale. The second window showing the clean image is simply the footage window inside AE.
https://www.9mmmedia.com/galant_screencap.jpg
Steve Roberts
June 6, 2005 at 4:57 pmTry turning field separation off on interpretation. It tends to mess up static clips.
Steve
