Activity › Forums › Adobe After Effects › Renders are problematic
Kevin Camp
November 19, 2010 at 11:00 pmi may have missed this, but are you running the latest version of cs5 (10.0.1, i believe)?
and i don’t see how a java update would have caused this, but i suppose it’s possible… if you disable/unistall nucleo, reboot and reset the preferences start a new project and see this behavior, i really don’t know what else might be to blame…
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Brannon Bates
November 19, 2010 at 11:16 pmHey Kevin, I did with no luck. My production is halted and i’m really worried about having to do a reinstall considering how many plugins i have. This is a nightmare. But, I guess if nobody has any more suggestions I’ll have to pull the trigger on it. Any last ideas on where the cache could be causing this?
Brannon Bates
November 20, 2010 at 9:40 amHey again, I was wondering if you guys might have a second look at this problem. I did try rendering out as .tif sequence, and .mov and the renders a clean. It’s only with .avi that I’m getting the flicker / phantom frame issue. So perhaps that codec is fried or something? Any thoughts on that?
