Rendering with Alpha-Channel
Posted by John Perez on May 29, 2022 at 9:33 amI rendered a shot using Apple’s Pro Res codec, but the file was too big. Is it possible to render an alpha channel as an MP4?
Graham Bernard replied 4 years, 2 months ago 3 Members · 11 Replies -
Graham Bernard
May 29, 2022 at 3:57 pmYou want small? – I use QT Animation.
You want MP4 – no dice.
Why do you insist on MP4?
Have you thought of using rendering a PNG sequence?
Ernest Rosado
May 30, 2022 at 9:12 pmDepending on what the purpose of your video is, you can render an MP4 of your video and then render an additional MP4 with your alpha channel only. These two files often result in a smaller total size than rendering a pure video + alpha channel and get similar results, provided you’re sending this to an editor who will recombine the two into transparent video.
If this is a final clip for consumption, then WebM is probably the most efficient codec with an alpha channel to convert to, but I don’t think Vegas supports it natively.
Graham Bernard
May 30, 2022 at 9:28 pmthen render an additional MP4 with your alpha channel only.then render an additional MP4 with your alpha channel only.
Are you suggesting that an MP4 can provide an ALPHA channel?
Ernest Rosado
May 31, 2022 at 2:24 pmNo. I’m suggesting the OP can render two mp4 files, one with the content, and the other one with an animated grayscale matte representing the alpha values in the first video.
John Perez
June 19, 2022 at 8:06 amPNG sequence? QT Animation. Are these rendering options in my V-19.
John Perez
June 19, 2022 at 8:20 amYou mean an PNG image sequence. Won’t that have a long render time and produce thousands of images?
Graham Bernard
June 19, 2022 at 9:01 amYes PNG Image sequence – correct.
Yes, these are rendering options in VP19 – correct.
QT is part of the “deprecated features” Tab and I have decided to have it available. I have QT7 installed, however, QT is no longer supported. Until I can obtain the ALPHA from MagicYUV working in VP19 I’ve got to be using the unsupported QT7 – it’s working.
Won’t that have a long render time and produce thousands of images?Won’t that have a long render time and produce thousands of images?
Depending on the length of the Event. I just did one and it was fast. You will get as many Images as there are Frames in your Event. You do the math, each Frame is a PNG.
Did you follow up on Ernest Rasado’s suggestion?
John Perez
June 20, 2022 at 8:42 amI watched a u tube and made the changes suggested by it and now it’s working. But the png method is a good back up. Thx
