Activity › Forums › VEGAS Pro › Rendering out to DVD from HDV – I want to preserve black bars – but DVD in encore?
Terje A. bergesen replied 19 years, 12 months ago 5 Members · 19 Replies
Markschneg
September 15, 2006 at 1:40 amYour system seems to have problems that run deeper than just Vegas, then. Sounds like it’s time for a fresh reformat and windows install. It’s near impossible to troubleshoot the one problem (exporting) when there are a slew of other things that seem to be contributing. With a fresh install of OS + software, you’re at least setting a better test bed for diagnosing the weird issue.
What are your system specs? They don’t show in your profile.
-Mark
Markschneg
September 15, 2006 at 1:42 amThat’s right – I read that FAQ a few weeks ago and said “I gotta store that in memory on the off chance it happens to me!” Needless to say, I promptly forgot (since my Vegas install has always behaved remarkably well, fortunately). Good call.
DavidD – did you try Mike’s suggestion? It could save you a bunch more running around.
David Del
September 15, 2006 at 8:36 pmAwesome, that fixed it. There was a jumbled string in there, not even sure what it was, anyways, deleted it and it works. Thanks for that.
David Del
September 15, 2006 at 10:13 pmIs it going to only be 720X480? I thought SD was 1280×720 – but in the custom settings it says 720X480…? Did I mix up on a setting?
Terje A. bergesen
September 16, 2006 at 1:05 am[DavidD] “Is it going to only be 720X480? I thought SD was 1280×720”
Eh, 1280x
would be HD. SD (in NTSC land) is 720×480 whether you use 4×3 or 16×9. —
Terje A. Bergesen -
David Del
September 16, 2006 at 2:24 pmOk, thanks for that – I was under the impression that HD was 1920×1080…
David Del
September 17, 2006 at 11:49 pmI am just discovering that rendering it out Widescreen 16:9 24p doesn’t give me widescreen with DVDA. What should I do then? Render it at 4:3 instead? that will give me the black bars?
Terje A. bergesen
September 18, 2006 at 10:58 pm[DavidD] “Ok, thanks for that – I was under the impression that HD was 1920×1080…”
It varies, and HD may be, but you were asking about SD, which is 720×480.
Terje A. Bergesen -
Terje A. bergesen
September 18, 2006 at 11:03 pmWhat are you rendering as? Be specific please. Rendering as 16×9 SD from Vegas should give you 16×9 SD in DVD Architect no problem, I do that all the time. I also just did a test-render with 24p (which I usually do not render to) and it worked fine.
Please specify what template you are using, what properties you are changing etc.
Terje A. Bergesen
