Activity Forums Adobe After Effects Rendering Odd and Even Frames..
  • Darby Edelen
    December 22, 2007 at 6:39 am
    [Justin Zion] “3D Glasses Effect only works with the old school Red and Green 3D glasses.”
    It has a couple of options other than the anaglyphic method, which I believe is where the confusion started.
    One of the options renders separate images to the upper field and lower field, which sounded a lot like what you were trying to do at first.
    If you need alternating full progressive frames, then I imagine you could find a way to cleverly manipulate your image to have a full frame in each of the fields and render to an image sequence. I have some ideas on this process, but I don’t have AE in front of me now to play with =(
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Chris Young
    March 18, 2009 at 7:46 pm
    I have a stereo video project that I would like to use the 3D glasses effect in order to achieve field separation using “Interlace Upper L Lower R” settings.
    I’m rendering two different outputs. The “left side” renders fine, BUT the “right side” renders without RGB information.
    If I use Animation codec or Blackmagic 10bit (RGB) I can get the “right side” render to output in color. Any other codec I use isn’t rendering the “right side” with color.
    I need to have a compressed codec in order to playback from a Virtual VTR set-up.
    I also tried using the Grid-track layer process and it yields the exact same results.
    Any help would be greatly appreciated!
    –cy
Page 2 of 2
