Activity Forums VEGAS Pro Rendering AVCHD to dvd
  • Mike Kujbida
    January 9, 2013 at 4:15 pm
    [Aleksandar Acimovic] “What do you mean by default presets?”
    Options – Preferences gives you a few tabs where you can set things.
    If you’ve never changed them, it’s possible that these folders are getting full and should be emptied out.
  • Aleksandar Acimovic
    January 9, 2013 at 4:52 pm
    Ok I installed DVDA PRO and ignored message, now my DVD is burning… I will notify what happen, how will it look in the end. Maybe problem was in Studio version….still one more thing, it needs to rerender audio, so can you tell me some info about audio settings in vegas, what bitrate to use for audio for dvd quality?
  • Stephen Mann
    January 9, 2013 at 5:06 pm
    Rerendering the audio is not a problem with quality, but if you use the Dolby AC-3 preset for DVDA, then the audio should be fine.
    If you were trying to use something like a WAV or MOV file, then that could have been the root of your original problem because a WAV file is huge compared to an AC3.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
    January 9, 2013 at 5:26 pm
    Ok, i have made one good 2 hr DVD working on computer and DVD player, Thanks a lot for all the effort you gave. I will be prepared for my working season.
  • John Rofrano
    January 9, 2013 at 5:51 pm
    [Aleksandar Acimovic] “avarage 4886”
    I thought I had already said that the average bit rate for your project should be 4611Kbps. 4886 was probably too much.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Rofrano
    January 9, 2013 at 5:53 pm
    Glad you finally got it all working.
    ~jr
  • Dieter Moreno
    January 13, 2013 at 11:11 am
    I’m having a problem too rendering a file to burn to video DVD that is obviously much smaller than Vegas “thinks” it is.
    Vegas was saying that “Approximate Size: 3.3 Gb”, then when the DVD was done burning its file and file sizes according to Windows Explorer are:
    /VIDEO_TS/VIDEO_TS.vob 232kb
    /VIDEO_TS/VTS_01_1.vob 970 Mb
    /VIDEO_TS/VTS_01_2.vob 955 Mb
    970 Mb + 955 Mb + 0.232 Mb = 1925.232 Mb = 1.93 Gb rounding to 2 decimal places
    Why does Vegas think that 1.93 Gb is 3.3 Gb?
  • Mike Kujbida
    January 13, 2013 at 2:17 pm
    [Dieter Moreno] “Why does Vegas think that 1.93 Gb is 3.3 Gb?”
    It’s not Vegas, it’s DVD Architect. It has a long history of incorrectly reporting file sizes.
  • John Rofrano
    January 13, 2013 at 2:39 pm
    Yea, we don’t know why it does this but you bring up a good point. Whenever you think that DVD Architect might be wrong, it’s a good idea to Prepare the DVD but don’t Burn it. Then check the VIDEO_TS folder size and if it’s under 4.7GB, go back and Burn from the existing folder and be sure that it will work regardless of any warnings you may get. DVD Architect allows you to do these two steps independently so why not take advantage of that to check your work.
    BTW, speaking of checking your work, you can preview the DVD in most DVD Player software simply by pointing it to the VIDEO_TS folder. This is a great way to check your work without burning a disc.
    ~jr
  • Dieter Moreno
    January 14, 2013 at 12:58 am
    I don’t have DVD Architect. I burnt the disc using the “burn to disc” feature in Vegas.
    It actually is Vegas that is estimating larger than expected file sizes on DVDs.
    My version of Vegas is Vegas Pro 10.
Page 3 of 4
