rendering 720p for DVD.. which render setting?
Gilles Gagnon replied 13 years, 11 months ago 4 Members · 19 Replies
Gilles Gagnon
September 10, 2012 at 9:20 pmHi John,
I rendered with the DVD template. When I preview the resulting mpg video in Media player the bottom section of the video shows “artifacts”… like horizontal sync problems when there is movement like a pan in the original footage.What’s going on? will this appear in the dVD as well?
Gilles
Gilles Gagnon
September 11, 2012 at 3:40 pmJohn,
Should I be rendering the audio separately or is it OK to render with audio?Gilles
Gilles
John Rofrano
September 11, 2012 at 3:56 pm[Gilles Gagnon] “Should I be rendering the audio separately or is it OK to render with audio?”
You should render the audio separately. DVD’s are build up from separate streams.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Gilles Gagnon
September 19, 2012 at 12:51 pmThanks John, I did.
By the way, which AC3 template should I use? I see two which have very similar names.Gilles
Mike Kujbida
September 19, 2012 at 12:55 pmDolby Digital AC-3 Pro is the one to use.
BTW, if you’re not happy with the DVD audio when listening to it (i.e. you find it to be too low), make the following adjustments to the stock template.Encode set to AC3;
Click on custom tab;
On the first tab set Dialog normalization to “-31”;
On the last tab marked preprocessing;
Set the Line Mode & RF mode profiles to “None”;
Now save this as a preset. -
Gilles Gagnon
September 19, 2012 at 1:38 pmThanks for the tip Mike,
Is this what you usually/always do?Gilles
John Rofrano
September 19, 2012 at 1:53 pm[Gilles Gagnon] “Is this what you usually/always do?”
I keep mine set to -30 because I felt -31 was a bit too loud so experiment some and see.
~jr
