Renderd video loses quality in VEGAS pro 17
Jimmie Brady replied 6 years, 8 months ago 6 Members · 15 Replies
Jimmie Brady
January 16, 2020 at 2:40 pmI installed the software and took screenshots of the specs. I noticed that the bitrate and stream size are extremly different. I couldn’t find a stream size option in Vegas but i did find a bit rate option. So i maxed the bit rate and renderd it. The renderd video was a little bit bigger (10mb) and it barrely made a difference.
Screenshot original file specs: https://www.mediafire.com/convkey/ed6b/iyigtszloakbb57zg.jpg?size_id=a
Screenshot renderd video specs: https://www.mediafire.com/convkey/fd97/jg4ubxpw11panhkzg.jpg?size_id=a
Bruce Brent
January 16, 2020 at 3:02 pmJimmie, I see what your problem is…..you’ve rendered HEVC which is highly compressed. Try Main Concept/Internet 1080p. Click “Customize,” click “two pass,” then click the “Project” tab and click “Video render quality” and click “best.”
Let us know how that turned out with Media Fire results as in the previous post.
Jimmie Brady
January 16, 2020 at 4:53 pmHi Bruce. I tried going to Main Concept MPEG-1 and MPEG-2 but neither of them had “Internet 1080p” and there was no improvement when i renderd a video in MPEG-2.
A screenshot: https://www.mediafire.com/convkey/a3e3/za36dtzumn55nsgzg.jpg
Ole Kristiansen
January 16, 2020 at 6:19 pmI can see that the Overall bit rate is 40.5 Mb/s for your recordings –
so try using: Magix AVC / AAC MP4 template – set Maximum (bps) 40,000,000 and Average (bps) 30,000,000 – and test if the quality gets better!Main Concept / Internet 1080p mp4, is legacy in 16, and 17 –
you can get it as follows – but don’t think mainconcept – not updated for many years – should not be better than Magix AVC / AAC!MainConcept AVC/AAC doesn’t appear as a render format in Vegas Pro 16.0
Maybe This Video can give you a few tips to get better quality!
Best & Fastest Sony Vegas Pro 15 Render Settings for 60 FPS
https://www.youtube.com/watch?v=gUjdQnJSdV0&feature=youtu.be
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jimmie Brady
January 17, 2020 at 12:20 pmIt works! The quality is the same as the original file. I want to thank everybody for helping me with this issue and have a good day.
