Activity › Forums › Adobe After Effects › Render time is extremely excessive
Ryan Hannebaum replied 12 years, 7 months ago 5 Members · 64 Replies
Ryan Hannebaum
February 11, 2014 at 10:37 pm[EricBowen] “AE is really best on a PC at this point”
What?! I refuse to acknowledge that Windows is better at anything in the creative world at this point in time. 🙂
Ericbowen
February 11, 2014 at 10:42 pmUnfortunately Windows and OSX have the same performance. So hardware decides the performance differences and those 2 GPU’s make 0 performance gain with AE where as 2 CPU’s mean a significant performance difference. Cant get 2 CPU’s on the nMPro so PC has the advantage. There is nothing OSX brings to the table that gives it any advantage to the Creative Market.
Eric-ADK
Tech Manager
support@adkvideoediting.com -
Ryan Hannebaum
February 12, 2014 at 3:44 pm[Dave LaRonde] “SEVENTEEN LIGHT LAYERS. Yipes!”
You’re right. 🙂 But I now only have 4 persistent light layers with one extra one that is periodically turned on. I eliminated the rest, either altogether or by replacing with fuzzy white solids to mimic the effect.
Ryan Hannebaum
February 12, 2014 at 3:44 pmEric, what about the following (understanding a PC is not an option for my company)?
3.5GHz Quad-core Intel Core i7, Turbo Boost up to 3.9GHz
8GB 1600MHz DDR3 SDRAM – 2X4GB
512GB Flash Storage
NVIDIA GeForce GTX 780M 4GB GDDR5
With 32 gig ram instead. -
Ericbowen
February 12, 2014 at 4:13 pmThat IMac would handle the rendering better than the MBP and the cooling would hold up better. Render times are still going to be over twice as long as they would be on a 8 Core. Just keep that in mind when planning deadlines. That same project I spoke of that takes 1.5 hours on a Dual 12 Core Xeon system takes well over 4 to 5 hours on a Quad Desktop and it’s only a min long comp.
Eric-ADK
Tech Manager
Ryan Hannebaum
February 12, 2014 at 5:55 pm[Walter Soyka] “If you want to apply an effect to the layer, you cannot also collapse transformations without breaking the render order.”
So if I wanted to duplicate a nested comp to apply a Fast Blur for a glow effect, how would I do that without breaking the 3D depth appearance? I’m struggling with it. I can either get the effect right but lose 3D depth, or not get the effect to mimic correctly…
Ryan Hannebaum
February 12, 2014 at 5:57 pm[EricBowen] “That IMac would handle the rendering better than the MBP and the cooling would hold up better. Render times are still going to be over twice as long as they would be on a 8 Core. Just keep that in mind when planning deadlines. That same project I spoke of that takes 1.5 hours on a Dual 12 Core Xeon system takes well over 4 to 5 hours on a Quad Desktop and it’s only a min long comp.”
OK….of the two spec sets I presented you, which would you recommend if you were forced to?
Walter Soyka
February 12, 2014 at 6:02 pm[Ryan Hannebaum] “So if I wanted to duplicate a nested comp to apply a Fast Blur for a glow effect, how would I do that without breaking the 3D depth appearance? I’m struggling with it. I can either get the effect right but lose 3D depth, or not get the effect to mimic correctly…”
Apply Fast Blur to each layer within the precomp individually, not to the precomp layer itself.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Ryan Hannebaum
February 12, 2014 at 6:04 pm[Walter Soyka] “Apply Fast Blur to each layer within the precomp individually, not to the precomp layer itself.”
Nasty, but OK. 🙂 On a related note then, is there a quick way to edit the properties of an effect for multiple layers at once? Selecting them all and then editing the property for one of the selected layers is not propagating to the other selected layers.
Ericbowen
February 12, 2014 at 6:18 pmThe Imac is better money spent because your not wasting money on what is not being used if this is primarily AE render. If you will edit on the system as well then the nMPro is the best performing choice and what I would get if I had to get a Mac and needed the most performance headroom for workflow and ram preview.
Eric-ADK
Tech Manager
